KICKING BACK -- not in a good way
Forum topic by Mary Anne posted 08-24-2010 10:09 PM 2092 views 0 times favorited 43 replies Add to Favorites Watch
View Mary Anne's profile
Mary Anne
1058 posts in 3141 days
08-24-2010 10:09 PM
Topic tags/keywords: kick back safety
The incident happened a little more than a month ago. The bruising has cleared up and I only have one small scab left. It is a little embarrassing that it happened in the first place, but more upsetting that I still can’t figure out how it happened. It is my practice to always stop to consider “Is this safe?” before I go near any of my tools, and this seemed okay to me. Obviously, something went wrong.
I was working on a box/cover for tissues, a simple project to give my Incra Positioner for the router table a go. The wood was hickory, thicknessed down to about 1/4”. I had four side pieces cut to 5”x6” with box joints cut into the long sides. I wanted to put in a 1/8” deep groove on each one to accept a top piece. I know there are several ways to go about this; I chose to put the piece on my table saw sled with a stop block to cut the shallow dado I needed. I figured on a couple of passes with my normal combo blade. I did 3 or 4 test cuts with scrap that was the same thickness and about the same size as my project pieces. The piece was snug against sled fence, firmly against the stop, and held flat with my fingers slightly to the side of the blade. There wasn’t even a hint of a problem or danger on my test cuts.
But when I put the first side piece for my box on the sled and barely touched it the saw blade, all hell broke loose… and so did my piece of wood. There was a loud BANG!! like a gun shot, followed so closely that it might as well have been simultaneous, a sickening impact to my gut and a stinging sensation in my fingers from the force of the wood kicking back off the blade. The wood exploded! When everything settled, there was one piece behind me, and another piece and several large splinters left on table saw. There were TWO sets of perfectly cut box joint marks on my belly, and several of them were bleeding. I am glad I was wearing a heavy canvas apron. I hate to think of the damage that would have been done if it was a larger, heavier piece of wood or if my fingers had been over the blade. Whew! I will, from now on, always, ALWAYS stand to the side no matter how small the piece or how safe I think the procedure might be.
Anyway, like I said, I know there are several other ways I could have accomplished this task, but was there something inherently wrong with putting my small piece of wood on a miter sled to cut the dado?
43 replies so far
View michelletwo's profile
2717 posts in 2948 days
#1 posted 08-24-2010 10:16 PM
were you cutting with the grain or against? Why use a sled? why not directly on table top? I’m not sure I understand your process..I think your piece might have tipped on the sled, the blade grabbed it and whammo…a thought..I don’t understand the sled & incra positioner in combo…
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3219 days
#2 posted 08-24-2010 10:18 PM
Mary Anne, From your description, I really don’t see anything wrong with your method.
I am scrathing my head wondering what might have happened. Maybe if you could post pictures of the process someone might offer some help.
Sometimes on smaller pieces, clamping to the sled is a wise choice. I do this all the time.
#3 posted 08-24-2010 10:18 PM
Another thought for the future..
I would have chosen a router in a table..and the piece directly on the table…
View rance's profile
4257 posts in 3093 days
#4 posted 08-24-2010 10:20 PM
Mary, I’m glad it wasn’t any worse than it was. Hope you heal quickly. I can’t quite picture what you were doing. I would be interested in a picture of your setup if you have the chance.
It almost sounds like you were ripping the pieces using your TS sled. Unless you have proper blocks set in place that sounds like a problem. Unfortunately, I’m not sure I understood your description. I’m sure I have it wrong.
View Dustin Dishner's profile
Dustin Dishner
11 posts in 2778 days
#5 posted 08-24-2010 11:06 PM
One thing that might have caused the blowing apart you described is the wood itself. Hickory is a very hard wood and with hardness you usually get brittleness. Since the side pieces were so thin, you likely got a lot of vibration in the wood (like when cutting a thin piece of plywood).
If that is what caused the problem, you might try clamping a support block made of some softer wood on top of the hickory side piece on your sled. This would allow the vibration to dissipate.
I hope you get to feeling better soon.
View Domer's profile
252 posts in 3299 days
#6 posted 08-24-2010 11:19 PM
I would second the thought of putting in directly on the saw table instead of a sled. You can put pressure over a larger area and the wood would be supported more over the whole piece. I would think it would be hard to put enough pressure over the whole piece on a sled.
The Gripper Ripper would be a good tool to use in an operation like this.
View Dennisgrosen's profile
10880 posts in 3048 days
#7 posted 08-24-2010 11:22 PM
AAuuch !!
hope you recover fast Mary Anne
take care
Mary Anne
#8 posted 08-24-2010 11:38 PM
Thanks for your responses and concerns. I appreciate it! I am fine now but for the last little scab.
To clarify: The Incra Positioner had nothing to do with cutting the dado; I only used it to cut the box joints on the router table. Sorry for the confusing extraneous info.
I was, however, using an Incra Miter Express sled with a Miter1000SE which is a rock solid, zero clearance setup that rides tight in the saw’s (Grizzly G0690) miter slots, no room for wiggle, tipping, or drop off. This setup, at the time, seemed like a good idea for putting a shallow dado in small, thin stock.
Kent, I think you are on track that I should have also clamped the piece to the sled. As secure as I thought everything was, something must have moved. The strange things was that it happened the instant I touched the workpiece to the blade; it just grabbed and blew up.
Dustin, the vibration of the thin wood and the brittleness of hickory also sound like major contributors to what happened. That is something I had not thought of in the last month of second guessing myself.
As for the “coulda, shoulda, why not this way or that?”... as I said, I know there are other ways. When I re-did the project, I dadoed the whole board up against the TS fence before cutting it down into the individual sides. That is my normal practice, but the dado was a design change. I probably would have used the router table for its easier, quicker setup, but I do not have an 1/8” bit. Yep, using the Grrripper would have been another excellent alternative that I could have used with less likelihood of kickback.
What I am asking is if there is something inherently inappropriate or dangerous in using a sled in this way?
#9 posted 08-24-2010 11:56 PM
I’m sure this could be safe, but I still wonder why you used a on are not cutting up thru the piece of wood, so it’s safe to use a pusher of some sort, directly over the piece. One of my rules in the shop is use the smallest blade/bit presentation I can..a 1/4 or 1/8 th bit leaves very little metal above the table top..a dado blade is lots more surface area to catch anything.(was the dado dull? any bad teeth?) Was there a knot? Is your sled on both sides of the blade? no dropping onto the table after cutting? I believe you had a vibration/slippage problem and you had an accident..glad you are ok…If you insist on using a sled for these operations you need to get your clamp right up close to the cut close as you can..keep the vibration down when the dado hits the wood. Or 2 clamps..
Mary Anne
#10 posted 08-25-2010 12:27 AM
I don’t insist on using the sled for these operations—it is just what I chose to use at that time, and I want to learn from the experience. While I consider myself a rookie at “fine” woodworking, I have owned and operated table saws and every other kind of power tools for nearly 40 years (eek) without incident. When something does happen, I go over it in my head until I ‘get’ what happened. When I understand, it is from there I may or may not use the same method in the future.
No dado blade; it was a sharp, nearly new high end Freud combo blade… can’t remember the exact model. No knots, no drop off. Yes, the sled covers both sides—zero clearance. I believe Dustin got it with the vibration and brittleness issues. And clamps might/probably would have prevented it.
View Kate's profile
400 posts in 3807 days
#11 posted 08-25-2010 12:37 AM
With small stock I personally think it’s dangerous not to use a push block that covers the cut (or holds both sides in the case of a through cut – with a Gripper for instance). I think you could have had the same sort of “explosion” happen on a router or with the table alone. I know a lot of people don’t use them, but they make me feel better.
As to the cause, I’m with Kent. I had a thin piece splinter like that on me once. It was LOUD!! Scared the out of me, but fortunately no injury except to the workpiece.
That’s my two cents.
Sorry you had the accident, but glad to hear you’re okay.
-- Kate,
13598 posts in 3273 days
#12 posted 08-25-2010 12:37 AM
MA .
even with your new explanation
i too have trouble understanding what you were doing .
i am how ever glad that you made it thru this without to much injury .
as i know nothing of the incra tools you used ,
i can’t imagine what you are talking about .
please show us pictures of a mock up as it was happening .
we can understand what happened better
you will be safer ,
and maybe someone else will be too in the future .
Mary Anne
#13 posted 08-25-2010 12:50 AM
Thanks, Kate. The annoying thing is that I had a Grrripper hanging on the wall right next to my saw and it is what I usually grab when I am doing the same thing on longer pieces, but for some reason, the sled made sense at the time for the smaller stock. Oops. :/
It’s dinner time now, David, but I’ll go down and take a photo after… if I don’t fall asleep first.
The whole thing is worthwhile if it prevents someone else from having the same thing, or worse, happen.
View Dale 's profile
415 posts in 3113 days
#14 posted 08-25-2010 12:52 AM
The important thing is that you’re ok.
-- Dale West Central Pa. Do it all, before last call.
View BroDave's profile
107 posts in 3747 days
#15 posted 08-25-2010 01:11 AM
Mary Anne, sometimes it isn’t what you did. Wood will “explode” sitting on your bench. I may be as simple as that piece of wood was “ripe” and you simply couldn’t have known or done anything to prevent it.
showing 1 through 15 of 43 replies
