I'm new to this website and this is my first post. And I've never posted on a website before so bear with me.
I'm planning on building a couple of cutting boards and a pizza peel and I want to inlay a letter into the projects. Basically a stylized initial of a friends last name. So it will need to withstand heat and water. I'm looking for ideas how to go about it, maybe what woods to use or not use and what types of adhesive I should use.
Epoxy would be one way to go for the glue. Plastic resin glue would work too, and easier to handle.
One idea that comes to mind is to put the inlay on one side, so they can flip the board when they want to use it, and have the inlay up for show when they are not.
I have an 18×24 inch Boos block that's 2 inches thick. Because it's so unwieldy, rather than cutting on the board and having to lug it to the sink, where it won't fit anyway, I use thin cutting sheets to protect it. That would be another option for protecting the fancy side of the boards.
Have you considered just cutting out the recess for the inlay and then filling it with tinted epoxy? Then you don't need to worry about gaps or whether the wood would fade, fall out, etc.
Welcome to Lumberjocks, Dave! Love your RC Plane! I fly full scale as well, but haven't done any RC stuff.
I did a pizza peel last year with a letter "G" inlay. It was surprisingly much easier than I anticipated. Marc Spagnuolo (Wood Whisperer) and I think Sean Rubino have really great videos on the process. You can see mine in my projects.
If you have a router you can use a Whiteside inlay bushing kit. Just make a template of the letter. The template needs to be the negative of the shape, and you use one template to cut the recess as well as the part to be inlaid. I would use an even grained wood like walnut or maple for the part to be inlaid.
Wow, what a great response from everyone. Thank you for the great ideas and I'll check them out.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
