| Forum topic by hydepark | posted 309 days ago | 234 views | 0 times favorited | 6 replies | ![]() |
309 days ago |
309 days ago |
Hollow core doors would be easy. Solid doors you have to worry about a lot more things. -- Gary, East TX -- The longest journey begins with a single step. |
308 days ago |
I would like to try to make a couple of doors, one from red cedar (mt. juniper) and one from blue stain ponderosa pine. The juniper (some call it aromatic cedar) dries straight and very little sweep or warp. The pondersoa is about the same. Solid or veneer? I have the logs-sawmill-vertical bandsaw and enough toys to do it. But….never done it before. Hydepark, please post pics of your progress. Thanks Kevin Davis -- To those who fight for it, life has a flavor the protected never know. Unknown, on an empty C-ration box. Khe Sahn 1968 |
308 days ago |
I have the FREUD set, and am about to try making some doors for the basement of my new shop. They will be Cypress, and the stock is all aged & milled up and cut to size .. just need to do the rail/stile joints and make some deeper mortises. I’ll let you know how they turn out .. I should get them done this week or next. The bits are a bit pricey, but VERY well made & matched. |
308 days ago |
Sounds like a big project. Please blog it if you do it. -- Maplewood, MN |
308 days ago |
The freud router bits are made for “cabinet doors”, not “passage” doors. As a rule the coped mortise and coped tenon are 3/8” long which IMHO are barely long enough for a cabinet door, let alone a passage door. I have hung hundreds of passage doors in my life. The only two jobs I did where the supplier of the passage doors were done with 3/8” tenons….......both projects the doors fell apart. Not to mention several people bringing the doors over to be re-built and refinished. If you are indeed making “passage” doors then you might consider making two doors, 5/8” thick and then glueing the two slabs together…........seen it done and it works quite well. In the event you are making cabinet doors then disregard everything I wrote. Good Luck |
307 days ago |
Finehomebuilding has a few good articles about building doors. Their door and window book contains some of the hits. -- -John "Do I have to keep typing a smiley? Just assume it's a joke." www.flickr.com/photos/gizmodyne |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1336 |
| Become a sponsor |
1778 |
| Become a sponsor |
123 |
| Become a sponsor |
371 |
| Become a sponsor |
108 |
| Become a sponsor |
Woodworking Trade & Swap
251 |
| Become a sponsor |
Coffee Lounge
1004 |
| Become a sponsor |
LumberJocks.com Site Feedback
284 |
