cleaning leather hones
« back to Woodcarving forum
Forum topic by Karda posted 01-07-2017 04:52 AM 511 views 0 times favorited 5 replies Add to Favorites Watch
View Karda's profile
Karda
957 posts in 460 days
01-07-2017 04:52 AM
Hi, how do you clean filing out of a leather hone after sharpening thanks
5 replies so far
View ksSlim's profile
ksSlim
1271 posts in 2797 days
#1 posted 01-07-2017 05:34 AM
Neat’s foot-oil and and old tooth brush. Use oil to soften the honing grit, brush to remove filings.
After filings are gone, allow oil to soak into leather, reapply honing compound.
This from an old saddle maker. Still using a hone board that I made new in 1970.
-- Sawdust and shavings are therapeutic
Karda
#2 posted 01-07-2017 05:37 AM
ok thanks
View ClaudeF's profile
ClaudeF
591 posts in 1614 days
#3 posted 01-07-2017 09:39 PM
Depends on what you are sharpening…
I have a very thin suede leather strop that has never been “cleaned”, as I see no need to do so Once every six months or so, I rub a little more compound on the strop. I’m a wood carver, so i’m only sharpening carving knives and gouges on my strop. I’ve recently switched to cereal box cardboard glued to a scrap bit of shelving, and compound rubbed onto the cardboard. It’s even thinner than the leather and does a great job. It hasn’t been cleaned in a year (cleaning would be replacing the cardboard). The problem with using leather and oil, in my opinion, is that the oil will tend to swell up the leather a little bit. As the blade passes over the leather during stropping, the leather will compress slightly, and then spring back up just as the edge passes. This will tend to round the edge and make the tool no longer carving sharp.
Only my opinion and experience. If leather and oil works for you, then good. Since switching to the cardboard, my knives seem to cut better…
Claude
-- https://www.etsy.com/shop/ClaudesWoodcarving
Karda
#4 posted 01-08-2017 12:14 AM
thanks for the suggestion, I haven’t tried the cardboard yet but I am. there are so many ways to sharpen I have to decide on a method and stick with that. I am ditching the arkansa stones for now, I have no idea of grit
Karda
#5 posted 01-10-2017 12:32 AM
Hi,Claude I tried the cardboard seem to work well, how would it work on a grinder wheel, my grinder is powered by a slow motor thank Mike
