Minwax wood putty
Forum topic by sedcokid posted 08-24-2010 05:31 AM 12935 views 0 times favorited 3 replies Add to Favorites Watch
View sedcokid's profile
sedcokid
2731 posts in 3566 days
08-24-2010 05:31 AM
I have a small container of Minwax wood putty, I used it once since the purchase date of May of this year. When I got it out to use it again today the putty was to hard to use. Now this is where I need some help, is there a way to soften it so that I don’t have to through it away? By the way it has a lid that I tightned in hopes this wouldn’t happen. I am open to any suggestions…
-- Chuck Emery, Michigan,
3 replies so far
View Gregn's profile
Gregn
1642 posts in 2951 days
#1 posted 08-24-2010 05:53 AM
It is suppose to be non harding but if it needs to be softened up a bit you might try mixing a little water in it.
http://www.minwax.com/products/wood_maintenance_and_repair/wood_putty.html
Since it cleans up with soap and water it should soften using a little water.
I added their link to check it out and maybe see what they suggest as well.
I have used wood putty with acetone base and have softened it up using acetone, but once it gets so old it will get lumpy.
View Vicki's profile
Vicki
1097 posts in 3312 days
#2 posted 08-24-2010 07:45 PM
I just add water. 2 other tips…...........put a piece of saran wrap over the top before putting the lid on and keep it in a zip loc…......after you get is soft enough…....3rd tip is I store things like that in the house as the temp changes are hard on them.
-- Vicki on the Eastern Shore of MD
View Matt 's profile
Matt
212 posts in 3717 days
#3 posted 08-24-2010 09:20 PM
I had the same exact thing happen to me, use a little water in it and seal it up well.
-- Hold on! Let me get the board stretcher!
