Finishing oak?
Forum topic by alittleoff posted 01-06-2017 11:01 PM 570 views 0 times favorited 4 replies Add to Favorites Watch
View alittleoff's profile
alittleoff
541 posts in 1452 days
01-06-2017 11:01 PM
I’m in the process of building a new bed using oak and black walnut. I’m wanting a close to natural finish. I did some grain filling on one post using linseed oil. The wood looks great the way it is but I was wondering about sealing it with a satin poly later. Would that be ok over linseed oil?
Gerald
View mrbob's profile
mrbob
182 posts in 745 days
#1 posted 01-06-2017 11:22 PM
Yes if it is dry, for the Poly. I would hit it first after the BLO with a 1.5-2lb cut of dewaxed Shellac, Zinzeer Seal coat is a dewaxed 2lb cut Shellac. The BLO does not need to be dry for that, just no excess on the wood, and I would wipe on the Shellac. Lightly sand with 320 grit, when the Shellac is dry, then do your Poly either water or oil base.
I do it all the time, one of my favorite finish combos.
The birds eye maple here was done that way.
alittleoff
#2 posted 01-07-2017 02:23 PM
Thanks, I was worried, thought I’d messed up. I’ll do it like you said.
Gerald
View splintergroup's profile
splintergroup
2342 posts in 1398 days
#3 posted 01-07-2017 03:03 PM
Just let the BLO dry for a few days first (I usually wait a week).
Rick Dennington
6245 posts in 3370 days
#4 posted 01-07-2017 03:16 PM
This is the process I use when I build furniture for customers, or our home…Most people want a natural look to their pieces, so I prep the wood good with the different stages of sanding, and wipe on mineral spirits, let it dry good, and wipe on about 1- 2 coats of Clear danish oil, depending on how the grain looks, and light sanding between coats. Once that’s dry, I use 3-4 coats of a fast drying wipe on poly, sanding with 600-800 grit paper between coats, and putting on the final coat to dry…..
-- " It's a rat race out there, and the rats are winning....!!"
