How to square up a piece of plywood
Forum topic by ragin_cajuns posted 01-06-2017 08:42 PM 2995 views 1 time favorited 10 replies Add to Favorites Watch
View ragin_cajuns's profile
ragin_cajuns
40 posts in 1105 days
01-06-2017 08:42 PM
I want to be able to square up pieces of 3/4 inch plywood and have been searching the web all day. I have seen several ways and I like this way the best – http://www.woodworkersjournal.com/375/
He uses a table saw and makes it jointer basically. If this was in video format it would be perfect. I’ve read it a few times and I think I understand what he is doing but wish there was a video explaining this. Anyone know of a video explaining how to do this?
Thanks,
10 replies so far
View hairy's profile
hairy
2783 posts in 3766 days
#1 posted 01-06-2017 11:25 PM
https://www.youtube.com/results?search_query=tablesaw+as+a+jointer
Also look for jigs to cut to cut 1 straight edge on a piece
-- My reality check bounced...
View Richard Lee's profile
Richard Lee
212 posts in 1009 days
#2 posted 01-06-2017 11:51 PM
How big are the pieces?
Squaring all 4 sides?
I use a sled on my tablesaw to make one straight edge then just the fence for the other edge.
View EugdOT's profile
EugdOT
254 posts in 789 days
#3 posted 01-06-2017 11:58 PM
- Richard Lee
I second that you should make a panel sled large enough to use on various sizes.
https://m.youtube.com/watch?v=4p0UTVUXh48
Richard Lee
#4 posted 01-07-2017 12:06 AM
https://www.youtube.com/watch?v=MnFxLxqnRWM
This is close to what i use, I can straighten an 8’ length.
ragin_cajuns
#5 posted 01-07-2017 01:05 AM
plywood pieces that are 2-3 feet wide and long. too big for my sled. i like the article i posted using the table saw as a jointer idea. just wish there was a video explaining it
View WhyMe's profile
WhyMe
1080 posts in 1794 days
#6 posted 01-07-2017 01:36 AM
To me the written instructions for the table saw jointer jig is very straight forward. The infeed edge is cut to ride flush to the right side of the blade and the outfeed edge is flush with the left side of the blade.
View clin's profile
clin
971 posts in 1230 days
#7 posted 01-07-2017 03:14 AM
I’m a bit confused what you want to do. Your title says “How to square up a piece of plywood”. Which sound like you want to create a plywood panel with square sides. That is a job for a big sled.
But, you link to a method for making a table saw jointer jig. So again, I’m confused what you are really trying to do.
Assuming you want to joint the edge, there are reversal different table saw jointer jigs. Some are really jujst sleds that you can clamp the rough stock to. Or as mentioned, you could use a large sled to joint an edge, AND to make another square edge cut.
While I’ve not built any, if you want something that works like a traditional jointer, the one I liked the look of uses a sacrificial fence and an added layer of plastic laminate (Formica or similar) to this fence.
Here’s a link to a PDF describing one example:
http://download.plansnow.com/plansnow-tablesaw-jointing.pdf
I found this on a page showing several other techniques.
http://www.toolcrib.com/blog/2009/02/6-table-saw-jointing-jig-plans-straight-edge-no-jointer
For my plywood projects, I just use a big sled I made. I think I can handle something about 36” wide. That makes it really easy. For boards, I still use the table saw, but I use a clamp-on edge guide commonly used for cutting plywood with a circular saw. It functions like many of the techniques that are based on attaching the wood to something with a straight edge.
-- Clin
View manjup2's profile
manjup2
3 posts in 738 days
#8 posted 01-07-2017 06:51 AM
http://skillonpage.com/personalized-learning-method/ guys go this link and most of skills is there for learnig ecpacially for who are willing to innovate new things liike wood architecture wood crafts so its better place to learn
manjup2
3 posts in 738 days
#9 posted 01-07-2017 06:53 AM
http://skillonpage.com/personalized-learning-method/ guys go this link and most of skills is there for learnig ecpacially for who are willing to innovate new things liike wood architecture wood crafts so its better place to learn so it is one type of personilze learnig things just go here and you’ll get lot of things related skills
manjup2
3 posts in 738 days
#10 posted 01-07-2017 06:56 AM
have anybody visited here? just click on this
there are so many “personalized learning method” you can get here about daily life utilizes there are so many
“personalize learning for students” available here, you can use your common sense to as a skills like wood crafts with solar lenses to as heater like this so many things is ,its amazing guyz
