| Forum topic by Ryan | posted 1005 days ago | 1041 views | 0 times favorited | 9 replies | ![]() |
1005 days ago |
Topic tags/keywords: lumb air dry Last week, I bought about 200 bf of fresh-cut walnut lumber. I just want to dry the good ones. However, my problem is I can tell |
9 replies so far
#1 posted 1005 days ago |
It will still air dry the same if planed first and maybe a bit faster because it is thinner. My question though is this, Since air drying is a lengthy process will it be any more of a problem to dry it all? Some of the problems with the pieces may not show up till after being air dried depending on your process of air drying. If you only dry ‘the good ones’, what if they go bad because of warp, cup, curl, and splits and you end up with not enough air dried wood. |
#2 posted 1005 days ago |
I haven’t thought about the board getting bad while drying. It may reduce the harvest volume |
#3 posted 1005 days ago |
My concern with planing before it is air dried, is that you may end up with much thinner stock when it comes time to start milling for use. Assuming that it was rough cut for 4/4 (being 5/4 rough cut) that after milling it would be less than 4/4 when finished. I would think even the bad ones would yield some usable lumber for small projects. -- I don't make mistakes, I have great learning lessons, Greg |
#4 posted 1004 days ago |
I don’t think I would run the green (wet) walnut through my planner. I sometime will use a hand plane to get a better look at the actual grain characteristics. I don’t plane the whole board, but just enough to get a good idea of the grain and color. pkennedy -- P Kennedy Crossville, TN |
#5 posted 1004 days ago |
Although most walnut doesn’t tend to warp if it is dried properly, I would not plane it until you are ready to use it. It is going to move a bit during drying and you don’t want to lose anything before you are ready to surface it for use. |
#6 posted 1003 days ago |
-yeah, Chiefk, i never can resist -ps -what is a bf? -- christine |
#7 posted 1003 days ago |
Christine, bf = board foot, unit of measure of amount of wood. A bf is the equivalent of a board twelve inches long and twelve inches wide and one inch thick. When purchasing thinner boards, anything under 1” thick is treated as being 1” thick for calculating the bf for the purchase… For small quantities of wood you can use parafin (sp?). Old candle stub would work or buy parafin such as Gulf Wax from store… Hope your hand is healing well. Herb -- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090 |
#8 posted 1003 days ago |
actually planing the surface reduces drying time. It is not cost effective in my sawmill operation, but does facilitate drying. -- Kyle Edwards, http://www.sawmillnc.com, Iron Station , NC (near Charlotte) |
#9 posted 1003 days ago |
To prevent end checking, use anchor seal or an equivalent that usually runs 9-12/gallon in bulk. Use them within 3 days of felling a tree unless winter and the sap is down or you are applying it needlessly. -- Kyle Edwards, http://www.sawmillnc.com, Iron Station , NC (near Charlotte) |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3554 |
15806 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
