| Forum topic by pollock | posted 1004 days ago | 422 views | 0 times favorited | 4 replies | ![]() |
1004 days ago |
Does anyone have trouble keep a blade in a Dewalt DW788 scroll saw. I can cut for a while and the blade pops out. I have tried everything by adjusting but to no avail -- Dean,Tulsa,Oklahoma |
#1 posted 1004 days ago |
Yeah, it happens every once in awhile. The two screws (thumbscrew on one side and set screw on the other side) get worn after awhile and the edges of them get rounded. You can take them both out and flatten them using a piece 400 grit sandpaper. I just lay a piece of sandpaper face up on the saw’s table and sand the end of the screws to get them as flat as I can. It gets the job done. Be careful taking the screws all the way out. If they are hard to turn spray some WD-40. The threads in the aluminum blade holder can get stripped quite easily. We keep an extra blade holder on hand just in case this happens. -- Scroll saw patterns @ http://www.sheilalandrydesigns.com ... Pens @ http://www.finestylus.com |
#2 posted 1003 days ago |
Keith, -- Dean,Tulsa,Oklahoma |
#3 posted 1003 days ago |
Dean Not sure if you know this or not but all blades come through with oil residue on them from the manufactoring process. IT is a good idea to wipe this oil off or else it builds up on the setscrews. To rid the oil, I like to sand both sides of the ends of the blades with a quick wipe of sandpaper. I also run a piece of sandpaper between the thumbscrew and the setscrew. The thumbscrew on the dewalt 788 should not round over as mentioned above because the tip of the thumbscrew does not spin on the blade. It is a cupped piece that should be able to move freely and this should be check from time to time. Just unscrew the thumbscrew and spin the cup piece on the end. If it does not spin from dust build up clean it up and hit with wd40. If the piece fell off you need to replace the thumbscrew. -- John T. |
#4 posted 1003 days ago |
Keith, John T. Thank both of you for the quick reply Dean -- Dean,Tulsa,Oklahoma |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15795 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
