Best way to apply Salad Bowl Finish?
« back to Woodturning forum
Forum topic by GAwoodworker posted 01-05-2017 04:58 PM 774 views 0 times favorited 3 replies Add to Favorites Watch
View GAwoodworker's profile
35 posts in 702 days
01-05-2017 04:58 PM
Hello Lumberjock community! I’ve been turning pens for a few years and have recently jumped into the world of turning bowls. I’ve found wax, mineral oil, tung oil varnish, and BLO to give nice finishes, but I picked up some General Finishes Salad Bowl Finish. I’ve tried it on two bowls now and am pleased with it, but cannot get that nice luster that I’ve seen on others. I’m able to get a nice satin finish with a few coats but it’s just not getting the wood to shine or pop like I’ve seen before. What are your preferred methods of application? Any techniques, tips, or tricks that you’ve learned or found helpful? Any comments or advice would be very much appreciated!
Thanks a bunch!
3 replies so far
View TheDane's profile
5384 posts in 3597 days
#1 posted 01-07-2017 07:10 PM
I let it cure for a week or two, then buff with my Beall buffing system.
View KYSean's profile
119 posts in 3530 days
#2 posted 01-07-2017 09:32 PM
I have always used Mahoney’s Walnut Oil with great results. Only oil I ever use.
View Ron Ford's profile
Ron Ford
208 posts in 1666 days
#3 posted 01-07-2017 10:06 PM
I apply three coats with a soft cloth, letting each one dry, then wipe off excess finish and let it sit overnight before putting the next coat. Like Gerry, I then buff it out on the Beall buffer and apply Ren Wax or carnauba wax as the last step.
You might want to be sure that you have left a really well sanded finish prior to applying any topcoat. What grit do you go to when sanding?
One other suggestion would be to apply Aqua Coat after finish sanding and before putting the salad bowl finish on. It does a great job of giving you an even better surface to work from.
Hope this helps!
-- Once in awhile I make something really great. Most days I just make sawdust.
