Bending wood
Forum topic by Mrowell posted 01-05-2017 04:25 PM 885 views 0 times favorited 9 replies Add to Favorites Watch
View Mrowell's profile
Mrowell
242 posts in 1373 days
01-05-2017 04:25 PM
Topic tags/keywords: question trick resource ash oak clamp shaping bending curved wall wood slat
I have recently been asked to do a decorative wood wall that will give a staggered plank look. Normally this is a piece of cake on a strait wall but this particular wall is more of a U shape. Does anyone have suggestions of the best way to accomplish this without steaming each individual plank and bending it to the wall? I was thinking maybe something like 1/8” oak plywood would work? Another option I thought about (Although time intensive) would be to resaw solid wood to 1/16’-1/8” and bend it in place? Any input would be great because it is a large wall so any ways to do this efficiently would be greatly appreciated.
-- Matt R
9 replies so far
View JBrow's profile
JBrow
1366 posts in 1154 days
#1 posted 01-06-2017 03:06 AM
Mrowell,
I doubt that my post is much help, but I can think of only the following methods for shaping the face of wood to conform to a curve. Each method has its own advantages and disadvantages. Without understanding the problem a little better, I am unable to say which method I would be inclined to use. However, if minimizing time is of paramount importance and varying thicknesses of material applied to the wall can be overcome, thin and hence bendable plywood would be a fast way to complete the wall.
1. Steam bending
2. Glue Laminating
3. Bending a Veneer on a bendable surface (e.g. veneer plywood)
4. Backside Kerfing, where a series of parallel kerfs are cut in the back side of the wood that are deep enough to permit the wood to bend
5. Assembled Staves, where edges of the staves are beveled at whatever angle is required to make the bend when joined together.
Backside Kerfing and Assembled Staves produce a segment of a polygon. If a smooth curve is needed, the show surface must be fared to produce that smooth curve; planning, scraping, and sanding.
If the inside corners of the U shaped wall are 90 degree corners, one more method may be an option. This method uses the table saw to gradually cut a cove into a corner transition piece. The coved corner board could then be beveled on each edge at 45 degrees for a smooth transition to the wall planks on the straight sections of the wall, since the coved corner board would be attached diagonally in the corner. Also the abutting straight section planks would also have to be beveled at 45 degrees. Getting tight joints between the coved corner board and the straight section planks could require some fine tuning, the extent of which would depend on how plumb and square the overlaid walls are and the accuracy of the bevels.
View Loren's profile
10477 posts in 3882 days
#2 posted 01-06-2017 03:14 AM
No efficient way to do it. It’s likely to be
a time consuming job. This is the sort of thing
clients will say they want, then you figure it
out and make a bid and they change their
minds.
You’ll have to bend solid wood, do some
fascimile with bending plywood, build it
up out of layers… you could also use bendable
plastic moulding and faux finish it to look
like wood.
runswithscissors
2916 posts in 2259 days
#3 posted 01-06-2017 04:45 AM
Using vertical staves would be one solution.
#4 posted 01-06-2017 05:00 AM
Yeah, def. try to sell the client on vertical staves.
I would charge like $3-5k for that wall and I am
already well set up and experienced with steam
bending. A $5k quote will chase off a client’s
dream pretty quick.
Doing staves is just like a standard time + materials
carpentry job.
I’ll note that a curved bulkhead on a yacht would
typically be done with staves. Try to find some
pictures of yacht interiors maybe to sell the client
on the idea.
View shipwright's profile
shipwright
8184 posts in 3032 days
#5 posted 01-06-2017 05:29 AM
If it’s just decorative, bendy plywood “boards” veneered to look like real wood would be an out but Loren’s right, vertical is the natural way to do that.
View aceline's profile
aceline
1 post in 1679 days
#6 posted 01-06-2017 05:44 AM
bending wood is one of the trending style of furniture.
View Lazyman's profile
Lazyman
2698 posts in 1621 days
#7 posted 01-06-2017 04:14 PM
How tight is the curve? Is it an inside curve or outside curve? The radius of the curve may dictate if it is even possible and how hard the various methods would be.
JBrow
#8 posted 01-07-2017 05:38 PM
Mrowell,
Since your original post I saw a product used on a This Old House project called Wacky Wood. It is extremely flexible and bendable. I know little more about the product but it may be worth a look.
http://packardforestproducts.com/products/plywood/hardwood-plywood/bending-plywood/
View Cooler's profile
Cooler
299 posts in 1077 days
#9 posted 01-09-2017 02:46 PM
There is bendable plywood.
See: http://packardforestproducts.com/products/plywood/hardwood-plywood/bending-plywood/
Saw kerf method: http://www.instructables.com/id/Raspberry-pi-media-player-1/
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
