Can I add pigment to spackling filler?
Forum topic by duckyone posted 01-05-2017 04:27 AM 936 views 0 times favorited 5 replies Add to Favorites Watch
View duckyone's profile
duckyone
7 posts in 1281 days
01-05-2017 04:27 AM
I am working on a dining table based around a reclaimed/repurposed chevron panel, and need to fill gaps (max 1/4”) between the pieces. One option that had been brought up to me was to use epoxy since it would fill and create a nice smooth finish, but I didn’t realize the cure time was so long. Additionally the temperatures are cold out in my garage right now, so I’m thinking of other options. I found a product that seems to be a good way to fill the spaces I need:
Only problem is, it is white… I know that you can dye wood putty using acrylic pigments found at any craft store. Can I do the same with the spackling?
Since the pieces that make up the panel design are all relatively even thickness, I have decided to go the rustic route and leave them at the surface with just a poly finish over to seal. The thread I posted on the table design can be located here: http://lumberjocks.com/topics/194114
5 replies so far
woodbutcherbynight
5267 posts in 2462 days
#1 posted 01-05-2017 04:37 AM
I would test it out on similar wood and see how it does.
View jerryminer's profile
jerryminer
935 posts in 1494 days
#2 posted 01-05-2017 07:38 AM
Yes, you can add pigment to spackle.
But I would not use that as a filler on a dining table. It is soft, and stays soft.
You can buy epoxy formulated for cold weather
View MrUnix's profile
MrUnix
6826 posts in 2252 days
#3 posted 01-05-2017 07:51 AM
West System epoxy can be used down to around 40F. Others brands have similar hardeners for low temp. Bringing it inside to a heated room would be the best bet though… there are no fumes, so it’s not like polyester resin where you get that wonderful smell throughout the house :)
duckyone
#4 posted 01-05-2017 03:00 PM
West System epoxy can be used down to around 40F. Others brands have similar hardeners for low temp. Bringing it inside to a heated room would be the best bet though… there are no fumes, so it s not like polyester resin where you get that wonderful smell throughout the house :)
- MrUnix
How long is the cure time?
Edit, nvm I just checked the link. Maybe I will fill the gaps with spackle and do the sealant coat with the epoxy – then I won’t need the epoxy to fill the 3/4 deep gaps and I can cut down on the time it will be tacky. I need it to be good to go by the 14th.
View McFly's profile
McFly
273 posts in 1080 days
#5 posted 01-05-2017 03:09 PM
X2 on the west systems epoxy. We use it all the time in our shop for high end projects.
