Hanging Swinging Carriage House doors
Forum topic by Rennovator001 posted 01-05-2017 03:27 AM 344 views 0 times favorited 6 replies Add to Favorites Watch
View Rennovator001's profile
Rennovator001
4 posts in 417 days
01-05-2017 03:27 AM
I am in the process of building 6 carriage house doors that measure 54×84x3.25”. The doors will be constructed of a 2” thick torsion box that is faced with Boral on the outside and bead board on the inside. Total weight for each door will be ~300lbs.
32” strap hinges will be through bolted with 5/16 carriage bolts to the door panels. Powder coated pintle jamb hinges will be attached to the 3×8 Douglas fir door jambs. The straps will have a loop that fits over a 5/8” pintle. All of the components are heavily powder coated. I am planning for a 1/8” gap between the door and the jambs and header and 3/8” between the door and floor.
My question is: Should I attach the strap hinges to the doors while the doors are perfectly spaced in the opening or should I cant the doors upward on the lock side to allow for some wear between the pintles and straps? Should I expect the weight of the door to cause some amount of drop on the lock side if I mount them perfectly level?
Any advice would be greatly appreciated.
Thanks
View jerryminer's profile
jerryminer
890 posts in 1349 days
#1 posted 01-05-2017 07:53 AM
You are smart to anticipate some drop. 1/8” is pretty tight tolerances for this type of door system. If I were doing this, I would seriously consider using adjustable strap hinges, which allow you to take out the sag without de-mounting anything.
With a fixed hinge, you will need to take out all the play in the hinge as you install. Strap hinges in general have a lot more slop than a typical butt hinge.
The weight of the door will pull the door away from the jamb at the top, and toward the jamb at the bottom. Be sure the top hinge is pulled tight and the bottom hinge is pushed tight at install. Hope that makes sense.
View JBrow's profile
JBrow
1327 posts in 828 days
#2 posted 01-05-2017 02:16 PM
Rennovator001,
If two hinges are used; each will carry 150 pounds. If the number of hinges is doubled from two to four hinges, each hinge would carry 75 pounds. As a result problems related to wear of four hinges and their moorings could be reduced. Awareness of the load rating of the hinges, if it can be discovered, could be useful information in determining whether more than two hinges are required.
Rennovator001
4 posts in 417 days
#3 posted 01-05-2017 02:21 PM
Jerry,
Thanks for the reply. I have never seen an adjustable strap hinge. Do you have a picture of one? Too late anyway because all 18 of the straps and pintles have been forged and powder coated. The only options I can think of for adjusting the door is to mortise the top hinge deeper into the jamb or pack out the bottom hinge. I guess that the holes in the straps could be elongated to allow for some adjustment.
I agree that a 1/8” gap is tight. The 3×8 jambs have been jointed and planed into straightness and the doors will have SingCore panels as the cores.
Rennovator001
4 posts in 417 days
#4 posted 01-05-2017 02:29 PM
JBrow
There will be three strap hinges. Not concerned too much about overall weight since the straps and pintles are 1/4” and the pintles are 5/8”. Don’t know how much the door is going to “sag” soon after installation from any slop between the pintle and eye of the strap. There will be some immediate wear because the thick power coating isn’t going to last long where the pintle and strap rub against each other.
I wonder if a really thin brass sleeve over the pintle would remove any sag after the paint wears off and the parts get used to each other.
Rennovator001
4 posts in 417 days
#5 posted 01-05-2017 03:12 PM
If we assume that the pivot point for any sag will be the middle hinge, the drop at the lock edge will be 1.28 times greater than the movement at the top and bottom hinges. I’m thinking that I should raise up the lock edge of the door about 1/16 (1/2 of the gap between the door and frame) when I drill the holes and mount the strap hinges.
If the door hinges ever wear to the point that the door drops straight down, I can add shims under the strap where it rests on the pintle hinge.
jerryminer
#6 posted 01-05-2017 07:48 PM
Jerry,
Thanks for the reply. I have never seen an adjustable strap hinge. Do you have a picture of one? Too late anyway ….
- Rennovator001
Maybe too late for this project, but here’s an example:
You can search on-line for “Adjustable Strap Hinge” and see lots more
