Alternative carbide knife insert for Jet JJP-12HH?
Forum topic by duc996 posted 01-04-2017 07:03 PM 1233 views 1 time favorited 2 replies Add to Favorites Watch
View duc996's profile
duc996
27 posts in 1700 days
01-04-2017 07:03 PM
Hi, has anyone found an alternative replacement of carbide inserts for the Jet jointer / planer combo? I have read on here someone mentioning a replacement but, could not find the thread. Any assistance would be much appreciated. Thank you.
2 replies so far
View Holbren's profile
Holbren
22 posts in 1206 days
#1 posted 01-05-2017 04:09 AM
The Byrd inserts should work just fine and are probably a better grade of carbide. The Jet head is made in Asia so the inserts are most like of the same origin and not as good as the German made ones Byrd uses. I’ve even seen some Chinese knockoffs with the “BT” on them but they are not from Byrd. The Chinese ones will work fine assuming they are made with uniform thickness just dull faster.
Any problems just return them.
https://www.holbren.com/Byrd_Tool_B4600
duc996
#2 posted 01-05-2017 01:21 PM
The Byrd inserts should work just fine and are probably a better grade of carbide. The Jet head is made in Asia so the inserts are most like of the same origin and not as good as the German made ones Byrd uses. I ve even seen some Chinese knockoffs with the “BT” on them but they are not from Byrd. The Chinese ones will work fine assuming they are made with uniform thickness just dull faster.
- Holbren
Thank you very much!
