Yet Another SketchUp ?
Forum topic by DonJ posted 08-22-2010 12:05 AM 898 views 0 times favorited 2 replies Add to Favorites Watch
View DonJ's profile
DonJ
250 posts in 3521 days
08-22-2010 12:05 AM
I’m making a box, where each side is made up of 3 pieces, stacked on each other (different types of wood). Initially, I had a side with only two pieces stacked, where I did a copy/move and flip. The initial 2 piece sets worked like they are suppose to, i.e., when I work on the left side, the right side reflects the same changes. After adding a third piece on top of the left side, copy/move and flipping it to the right side, I can’t get the right top side to “sync” to the left top side when making changes. Any suggestions? Thanks.
-- Don, San Antonio, TX
2 replies so far
View PurpLev's profile
PurpLev
8535 posts in 3642 days
#1 posted 08-22-2010 12:21 AM
was the right side made into a component prior to move/copy flipping it to make the left side?
View DonJ's profile
DonJ
#2 posted 08-22-2010 01:18 AM
Yes and no; I erased the left side and right side, then added the new piece on the left side WHILE in the edit mode. Then moved/copied and flipped…worked like a champ. Thanks!!
