| Forum topic by bigike | posted 1002 days ago | 1184 views | 0 times favorited | 3 replies | ![]() |
1002 days ago |
Topic tags/keywords: vaneer joints wood How can i make a bookmatched joint seamless using vaneer? I already jointed The vaneer between two pcs of wood that was made flat and square. -- Ike, Big Daddies Woodshop, http://www.icombadaniels@yahoo.com |
3 replies so far
#1 posted 1002 days ago |
Use veneer tape. Water activates the glue and as you dry it with an iron, it shrinks slightly pulling the two pieces together. You can also use easy release blue painters tape. Stretch it across ever couple of inches and then run a reinforcement piece down the entire joint. This will keep the pieces from sliding over top of one another. -- http://www.niceashplanes.com/ http://www.efcabineture.com/ |
#2 posted 1002 days ago |
You don’t need an iron to dry veneer tape. It dries on it’s own in minutes. I tape the back side with blue tape to hold it together, then flip it over and apply veneer tape. Once the veneer tape is dry, remove the blue tape and glue the veneer down in the press. -- Gerry, http://home.comcast.net/~cncwoodworker/CNC_Woodworker.html |
#3 posted 1001 days ago |
You don’t need to iron it to dry it but it sure makes it faster. Thats just the way I was taught. -- http://www.niceashplanes.com/ http://www.efcabineture.com/ |
| Forum | Topics |
Woodworking Skill Share
8785 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1526 |
3543 |
15758 |
Hand Tools
2031 |
Jigs & Fixtures
494 |
Wood & Lumber
2834 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6151 |
