finish to withstand 450° contact?
Forum topic by mzimmers posted 01-03-2017 07:41 PM 798 views 1 time favorited 18 replies Add to Favorites Watch
View mzimmers's profile
mzimmers
202 posts in 4059 days
01-03-2017 07:41 PM
Hi, all -
I’m building a pie safe, where baked goods are to be put to cool. I’m making the cabinet and shelves out of ash.
I’m wondering whether there’s a kind of finish out there that would make it safe to put glass or tin pans straight from the oven into the cabinet. I’m guessing not, so I’m thinking of putting in some 1/8” steel rods to stand-off the pans from the wood.
Any input is most appreciated.
-- M. Zimmers
18 replies so far
View Ron Aylor's profile
Ron Aylor
2649 posts in 791 days
#1 posted 01-03-2017 07:50 PM
I would finish the interior with plain old linseed oil … linseed oil and shellac on the exterior.
mzimmers
#2 posted 01-03-2017 07:57 PM
Really? Linseed oil is that tough?
-- M. Zimmers
View jbay's profile
jbay
2666 posts in 1042 days
#3 posted 01-03-2017 08:10 PM
I like the idea of some runners out of 1/8” aluminum. Just cut a saw kerf and lay them in.
mzimmers
#4 posted 01-03-2017 08:12 PM
I was thinking iron rather than aluminum, as it makes for a better heat sink, but I imagine either would work. I’m just wondering whether I’m over-thinking and/or over-engineering this.
-- M. Zimmers
View jbay's profile
jbay
#5 posted 01-03-2017 08:15 PM
I wouldn’t want to place them directly onto the shelf.
Another thought may be tempered glass on top of the shelf.
Ron Aylor
#6 posted 01-03-2017 08:15 PM
- mzimmers
Sure … might have to touch it up every few years. Take a look at an antique pie safe … there might be a bit of discoloration, but that adds character!
View Redoak49's profile
Redoak49
3523 posts in 2132 days
#7 posted 01-03-2017 09:37 PM
I do not think a pie safe was meant to store hot food but just to keep insects and animals from food.
View papadan's profile
papadan
3584 posts in 3511 days
#8 posted 01-03-2017 10:53 PM
- jbay
+1
mzimmers
#9 posted 01-03-2017 10:55 PM
I decided to go belts and suspenders with this one: I put in two aluminum runners, and I’ll finish with linseed oil.
Thanks, all.
-- M. Zimmers
View johnstoneb's profile
johnstoneb
3011 posts in 2316 days
#10 posted 01-03-2017 10:55 PM
You need an air gap all the way around any pastries when cooling. Your idea would work well steel or aluminum.
-- Bruce, Boise, ID
View bbasiaga's profile
bbasiaga
1240 posts in 2138 days
#11 posted 01-03-2017 11:23 PM
As a baker, i would say make sure to build a big vent in your pie safe. You generally try and cool hot things on an open rack right out in the, well – open. Otherwise the water vapor will condense and rain back down on what you baked, ruining its texture. Also the moisture trapped in the safe will want to mold.
Brian
View JBrow's profile
JBrow
1366 posts in 1063 days
#12 posted 01-03-2017 11:28 PM
Mzimmers,
I tend to agree with Redoak49, a pie safe keeps the pies safe and is not a very good cooling rack. About 10 minutes on a cooling rack drops the temperature of the pie and pie pan quite a bit. After the pie has cooled a bit it could go into the pie safe. But even then, I would prefer to let the pie cool for a couple of hours so that the filling can set up. A pie safe would reduce the rate at which the pie would cool and leave the filling runny over a longer period of time.
However, I think a pie safe that offers an integrated cooling rack would be an interesting design. The cooling rack could be open to the air so finishing would be less of an issue. Once cooled, the pie could be transferred to the enclosed pie safe.
But if the pies are to go directly from the oven to the pie safe, metal stand-offs proposed by jbay would be a may or may not be a good approach. While the metal stand-offs would keep the hot pie plate from direct contact with the wooden shelf, the heat from the hot pie could dry out the upper surface of the shelf. If this happens, the shelf could cup. Even if the cup is very slight, it could be enough to prevent the pie plate from setting on the shelf without rocking. Therefore either the tempered glass shelves suggested by jbay or metal racks like cooling racks and oven racks would avoid the potential problem of cupping shelves.
No matter when the pies are placed in the pie safe, steering clear of interior finishes other than maybe walnut oil or mineral oil may be the better options. No interior finish at all may also be worthy of consideration. Penetrating and film finishes I have used off-gas for quite some time. I suspect that a fresh baked cherry pie with a hint of an off-gassed solvent would detract from culinary delight otherwise expected from that first bite.
View cabmaker's profile
cabmaker
1740 posts in 2952 days
#13 posted 01-04-2017 12:18 AM
Keep in mind…..the kindling point for most wood species is approx 400 degrees F
View ArtMann's profile
ArtMann
1079 posts in 959 days
#14 posted 01-04-2017 02:52 AM
I use a CNC router to carve trivets for sale. I did extensive testing of finishes to answer that very question. I make stuff to use rather than just look at. What I found is that Minwax semigloss Polyurethane varnish does not melt, discolor or otherwise degrade when you repeatedly put a casserole dish preheated to 450 on it. Of course, the trivets are not solid but have grooves and patterns cut in them for cooling purposes. Here is an example:
mzimmers
#15 posted 01-04-2017 04:25 PM
Wow…so much to know, and so much to think about. Thanks again, everyone. Based on what JBrow and others mentioned about gassing off, I think I might forego the interior finish, at least for now.
And, I suppose I’ll use the cabinet for storage, not for cooling. I’ve already installed the stand-offs, but they won’t hurt anything. For the stand-offs, I got some 1/8” x 1/2” aluminum flats from Lowes, and cut a 1/8” groove 1/4” deep. They were a bit loose, so I put a few spots of super glue in to hold them. If I’d been really worried about heat transfer, I’d have made them from steel and probably a little taller.
Oh, and Art…that trivet is disgustingly beautiful. Every time I see someone post something like that, it reminds me what a rookie I still am at all of this…
-- M. Zimmers
