When encountering tetris shapes when laying out, best way to cut?
Forum topic by Holbs posted 01-03-2017 01:13 AM 443 views 0 times favorited 3 replies Add to Favorites Watch
View Holbs's profile
1818 posts in 1961 days
01-03-2017 01:13 AM
Topic tags/keywords: tetris laying out jigsaw
Surprising I have not yet encountered this yet. And no luck with searching on LJ’s. Maybe it’s common sense and I’m just missing it ;) When you encounter some pieces while laying out that resemble tetris shapes (to conserve plywood material), how do you go about cutting them out? I used my grizzly track saw rail and bosch jigsaw. Too unwieldy for bandsaw use.
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
3 replies so far
View bbasiaga's profile
1158 posts in 1926 days
#1 posted 01-03-2017 01:31 AM
That’s about it for me too. Circular saw or jigsaw.
Hand saw is also an option, for people that can saw straight.
Drill a hole in the corners if you can. Makes the jig saw easier to apply.
View wuddoc's profile
268 posts in 3649 days
#2 posted 01-03-2017 01:42 AM
One solution would be locating someone with CNC equipment. In their software programing they can create the various configurations. Then using a nesting program a CNC would cut the shapes with minimal material loss.
-- Wuddoc
View JoeinGa's profile
7733 posts in 1938 days
#3 posted 01-03-2017 01:14 PM
If the side edgess are long enough I start with a circular saw, then do the “corners” with this
