More table saw issues
Forum topic by LucasWoods posted 01-03-2017 12:05 AM 639 views 0 times favorited 7 replies Add to Favorites Watch
View LucasWoods's profile
LucasWoods
445 posts in 1572 days
01-03-2017 12:05 AM
I am taking apart a G1022 TS to clean it up, learn about how it workes more etc and to eventually change all the bearings on it. First I need to figure out how to take this thing apart! The part I am having trouble with is the linking bar. (See picture) I don’t have the correct metric socket wrench but I do have an adjustable wrench that fits well and tight but man I put all of my weight into it and that nut will not come off the linking bar… help please!
I do have a propane torch but it is out of propane and have never heated bolts/nuts to get them off before…
Any tips would be appreciated!
-- Colorado Springs, CO - USAF
7 replies so far
View lumberjuniorvarsity's profile
lumberjuniorvarsity
84 posts in 1134 days
#1 posted 01-03-2017 01:42 AM
Assuming there’s no loctite on those threads – have you tried spraying lubricant on it? WD-40? Aerokroil?
You could also try sliding a pipe over the handle of your wrench to increase the amount of torque applied – like a breaker bar.
lumberjuniorvarsity
#2 posted 01-03-2017 01:44 AM
And if you don’t have the right size wrench I’d make sure your adjustable wrench is as tight as you can possibly make it before attempting if it’s taking that much force to loosen.
View johnstoneb's profile
johnstoneb
3072 posts in 2412 days
#3 posted 01-03-2017 02:07 AM
get the right sized wrench without it you’ll end up rounding that nut over then you will have problems.
-- Bruce, Boise, ID
lumberjuniorvarsity
#4 posted 01-03-2017 02:14 AM
get the right sized wrench without it you ll end up rounding that nut over then you will have problems.
- johnstoneb
Yeah, that’s probably the smartest. And use a box end wrench.
View Madmark2's profile
Madmark2
409 posts in 827 days
#5 posted 01-03-2017 02:20 AM
Put a drop of penetrating oil on the nut/bolt seam and rap it once firmly, let it set 10 min, and then attack it.
M
View HorizontalMike's profile
HorizontalMike
7770 posts in 3153 days
#6 posted 01-03-2017 01:15 PM
- johnstoneb
BINGO that! And make sure you use the enclosed/rounded end and NOT the open end…
RE penetrating oil—Use PB Blaster. WD40 and others don’t help that much.
View drcodfish's profile
drcodfish
124 posts in 1191 days
#7 posted 01-04-2017 12:14 AM
- johnstoneb
This almost doesn’t need saying, ... but I guess it does. If you think you are having trouble now, how much fun do you think you will be having once you have that nut nicely rounded off? not to mention how embarrassing it will be when you are back posting here asking for advice on working with a rounded off nut?
-- Dr C
