Shop Filter
Forum topic by Gerald Thompson posted 01-02-2017 10:32 PM 647 views 0 times favorited 3 replies Add to Favorites Watch
Gerald Thompson
1142 posts in 2474 days
01-02-2017 10:32 PM
I have the fan from the air handler I kept after a new A/C install. It is nine inches in diameter and eight inches wide. It is the squirrel cage type.
The motor is new. It is 220v, 2.7 amp and 1.5 hp. I would convert to 110v
This seems skimpy in HP to me. Could it be used as a shop filter?
Thank you.
-- Jerry
3 replies so far
View eflanders's profile
eflanders
320 posts in 2089 days
#1 posted 01-03-2017 01:34 AM
If you leave the motor wired for 220, it will use less electricity and will likely last longer to boot. As for the horsepower rating, that motor should move a lot of air. You won’t know until you actually try it. I do know of a few guys that made theirs very successfully with the same type of blower etc.
woodbutcherbynight
5832 posts in 2648 days
#2 posted 01-03-2017 03:14 AM
Considering that the air handler blew air into a entire house unless you have a very large shop it is more than up to the task. Do keep if 220 if possible as eflanders pointed out they run better and last longer. My WEN air filtration system motor is rated at 1/16th I believe.
View Carloz's profile
Carloz
1147 posts in 831 days
#3 posted 01-03-2017 05:34 AM
If you leave the motor wired for 220, it will use less electricity and will likely last longer to boot. As for the horsepower rating, that motor should move a lot of air. You won t know until you actually try it. I do know of a few guys that made theirs very successfully with the same type of blower etc.
- eflanders
An induction motor will not use less electricity and will not last longer when used in 220V circuit. In fact it will not event notice.
I do not know why the misconception about magic of 220V is so widely spread.
OP. For the air filter it is more than you need.
