Rotary Phase Converter
Forum topic by Binn posted 08-20-2010 05:09 PM 4118 views 0 times favorited 13 replies Add to Favorites Watch
View Binn's profile
Binn
93 posts in 3187 days
08-20-2010 05:09 PM
Can anyone tell me what you would recommend or have experience using Rotary Phase Converters?
I bought a Grizzly 10hp 3phase table saw and I need a phase converter , I am inquiring about 2 manufactures ; Kay Industries and Phase-A-Matic converters.
Does anyone own or use these?
8/20/2010
-- Barry, Louisiana
13 replies so far
TopamaxSurvivor
18422 posts in 3909 days
#1 posted 08-20-2010 06:36 PM
Get a Variable Frequency Drive, it will be much better amd less expensive than a phase converter. Search this site for the name of a company that others have had good luck with.
View Binn's profile
Binn
#2 posted 08-20-2010 07:41 PM
Thanks guy’s for your help, I am going to check into these options.
-- Barry, Louisiana
View Elksniffer's profile
Elksniffer
102 posts in 3631 days
#3 posted 08-20-2010 07:46 PM
I installed an Allen Bradley VFD (Power Flex) on a 3 phase lathe motor and it works great.
It was simple to wire in, rated for a couple more HP than I needed, makes a faint buzzing noise and has all the power I need.
TopamaxSurvivor
#4 posted 08-20-2010 07:59 PM
I should metin there is a small chane the VFD will trip out on short circuit if it is not a VFD rated motor. I doubt that it is in a older saw. Yoiu could check this with a high voltage megger. If it doesn’t read at or near infinity, you may have problems using the VFD. In that case, use a rotor-phase.
View extremehobbiest's profile
extremehobbiest
42 posts in 3220 days
#5 posted 08-20-2010 11:10 PM
I have a Kay converter and it is a very good machine with excellent customer service. Phase-a-matic is also good. With a 10HP saw motor, I wouldn’t choose a VFD for use as a phase converter.
Another option is the Phase Perfect which is a digital unit. I know of several folks that rave about this one. It is expensive though.
One thing to watch out for is the HP ratings that some manufacturers use. When Kay sells you a 10HP phase converter, it will start a 10HP motor. This is not the case with all manufacturers so do your research and talk to the sales engineering folks. If they are not asking you what type of machine you want to run and ask your machine details, start looking elsewhere.
View John Ormsby's profile
John Ormsby
1288 posts in 3970 days
#6 posted 08-20-2010 11:49 PM
I also have a Kay converter. They are excellent. I also installed what is called a Buck/ Boost transformer to balance out the voltages on the three legs. They are now within =/- 1 volt of each other. This is necessary thing when running machines with a lot of electronics on them.
-- Oldworld, Fair Oaks, Ca
TopamaxSurvivor
#7 posted 08-21-2010 02:27 AM
rick3ddd, I just mentioned that because there is a small chance the insulation in an older motor will not hold up to the high switching frequency of many drives. If the drive trips out on ground fault when it is installed, that is most likely the problem. I would not expect a lay person to get a high voltage meggar and start testing. A used one will be $1200-1500!! :-)) Most electricians are at a loss as what to do with it or what it is really telling them :-((
If it trips on ground fault, that is most likely the problem . You will have a hard time finding someone to trouble shoot it. The drive customer service may be able to help unless they are phone people reading off a screen. Most electrician wil be clueless. I just thought I’d mention the possibility for info sake and incase it happens.
On a job I was recently on, an old motor would not work with the new drive conversion. The 30 something electrician didn’t have a clue. The 30 something drive tech wasn’t too sure, neither knew how to test the problem. The meters they were carrying didn’t tell them anything. Unfortunately, that is the way it is out there in electric land these days. If you tell the customer they need a new 25 hp 3 phase motor or the $4k drive they just bought isn’t any good, it is spendy and embarrassing to be wrong :-))
View Binn's profile
Binn
#8 posted 08-21-2010 04:09 AM
Hey guy’s slow down a bit, I know my wood but I know nothing about electricity and don’t want to know. I leave that to the experts, but anyway topamx my saw is almost new was purchased Nov.09.
I talked to Ed Fry w/ electricmotorswarehouse today and he said I might not be able to use a VFD because of the computer electronics in the ele. panel. He mention some things but first he needs the wiring diagram of the saw.
I’ll let him or others figure it out, all I want is the best cheapest way of connecting this machine so I can go to work.
This is a grizzly G0501 10hp 3 phase slider panel saw. Kay Industries wants $1750.00 and Phase-A-Matic wants $1956.00, the previus saw owner uses the phase-a-matic for his machines and recommends them.
-- Barry, Louisiana
View Michael Murphy's profile
Michael Murphy
453 posts in 3239 days
#9 posted 08-21-2010 04:33 AM
I have a rotophase 5 hp phase converter and have been using it for about 30 years with NO trouble at all. I bought it used for about $150.00. It starts my 3 hp unisaw and 5 hp 3 phase compressor all the time, no problem, with the saw running the compressor still can kick in. I have had other 3 phase equipment come and go and it seems to work with them all. The rating is supposed to be what it is rated to start.
If you are buying a 10 hp saw you are in a league above most of us here on LJ. I was a professional Cabinetmaker for 20 years and never had a motor over 7.5 hp and that was a sander. I would be afraid of a 10 hp saw. There is such a thing as too much power for the application.
-- Michael Murphy, Woodland, CA.
TopamaxSurvivor
#10 posted 08-21-2010 05:22 AM
I haven’t delt with Grizzley electronics, but welders have been a little picky in the past :-)) I doubt if the electronic baords are going to like the switching trying to fool them into thinking there is the proper 3 phase voltage. Motor winding don’t seem to mind if thery have teh proper insulaion. I would suggest a rotary vs an electroinc rotophase if you have electronic controls down stream. Good luck.
View makfin's profile
makfin
3 posts in 3019 days
#11 posted 10-11-2010 02:56 AM
This is an easy one check out www.phaseconverterspecialist.com they can take care of you and its a simple two wires in and three wires out. Ya they make it that easy.
View Binn's profile
Binn
#12 posted 10-15-2010 05:00 PM
Makfin have you bought or used this companies phase converters?
-- Barry, Louisiana
makfin
#13 posted 10-15-2010 06:26 PM
My company purchases them and I install them for farmers in the area. I like the simple hookup and durability of their system. Their web site is user friendly and has a contact page where you can tell them what you need. We order our systems and get them in about two weeks.
