Dado Shelves adjacent to each other?
Forum topic by Jeff B. posted 01-02-2017 08:19 PM 629 views 0 times favorited 11 replies Add to Favorites Watch
View Jeff B.'s profile
Jeff B.
6 posts in 660 days
01-02-2017 08:19 PM
Hello,
When using 3/4” plywood, can I use 1/4” Dados to support shelves directly next to each other, or must they be staggered. Is the remaining 1/4 ” of material enough? . In this instance, the shelves will span about 3’, but will only support a total of about 10-12lbs (empty suitcases)
Thanks for your advice
11 replies so far
View MrRon's profile
MrRon
5086 posts in 3390 days
#1 posted 01-02-2017 08:41 PM
You should have no problem. The thickness of the shelf itself will contribute strength at the joint. Just make sure the fit is as close as you can get. The glue will also add support.
View jerryminer's profile
jerryminer
944 posts in 1588 days
#2 posted 01-02-2017 09:36 PM
+1 ^^ I’ve done this many many times. It works fine.
View pintodeluxe's profile
pintodeluxe
5757 posts in 2960 days
#3 posted 01-02-2017 10:09 PM
I would avoid it. 1/4” is not enough material for adequate support. Consider not only current use, but potential future uses (heavy books?). You posted this question because your gut didn’t like the look of it. Trust your gut.
View johnstoneb's profile
johnstoneb
3014 posts in 2319 days
#4 posted 01-02-2017 10:21 PM
It will work fine. I have done it several times. Your shelf needs to be thick enough to hold the load without sag. The load at the joint is vertical.
-- Bruce, Boise, ID
View bondogaposis's profile (online now)
bondogaposis
4993 posts in 2498 days
#5 posted 01-02-2017 10:37 PM
Yes, it will work. There are few things to consider though. First is that 3/4” plywood is not 3/4” thick. So if you cut 1/4 dados adjacent to each other the remaining piece is somewhat less than 1/4’’ which isn’t much. What I do in that situation is to cut the dados 3/16” deep, that gives 1/8” more thickness on the case.
-- Bondo Gaposis
johnstoneb
#6 posted 01-02-2017 10:39 PM
+1 Bondo
-- Bruce, Boise, ID
View jbay's profile (online now)
jbay
2678 posts in 1045 days
#7 posted 01-02-2017 10:43 PM
I would avoid it. 1/4” is not enough material for adequate support. Consider not only current use, but potential future uses (heavy books?). You posted this question because your gut didn t like the look of it. Trust your gut.
- pintodeluxe
Would you please explain why?
Jeff B.
6 posts in 660 days
#8 posted 01-02-2017 11:54 PM
Thanks very much for the thoughtful replies.
117234 posts in 3723 days
#9 posted 01-03-2017 12:11 AM
Hi Jeff welcome to Ljs
I agree 1/4” will support the weight you talking about and perhaps as little as an 1/8” will work.Through the years I’ve gotten in the habit of making my dados half the thickness of my 3/4” ply but that’s not necessary.It will depend on your material if you want to go to the other extreme of only using 1/8 dados.
View jmartel's profile
jmartel
8155 posts in 2296 days
#10 posted 01-03-2017 01:03 AM
You could compromise and do 3/16” depth. That leaves you with 3/8” web between shelves while giving you a deeper socket than 1/8”.
View wuddoc's profile
wuddoc
314 posts in 3864 days
#11 posted 01-03-2017 01:29 AM
You may want to file this from WoodBin. The Sagulator or deflection versus span and other variables.
http://www.woodbin.com/calcs/sagulator/
-- Wuddoc
