| Forum topic by Milo | posted 1004 days ago | 1124 views | 0 times favorited | 10 replies | ![]() |
1004 days ago |
Topic tags/keywords: jig question I’m looking for some advice on jointing and planing over sized wood. I’ve got 12 inch boards and a 6 in jointer. I’d appreciate any ideas you have. Thanks! Milo -- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear... |
10 replies so far
#1 posted 1004 days ago |
You can make a planer sled, should be plans for one on this site. I also remember seeing an ingenious router jig by a member, GaryK, that addresses this exact problem. -- http://www.niceashplanes.com/ http://www.efcabineture.com/ |
#2 posted 1004 days ago |
Take them to a shop that has appropriately sized tools for te job. Or get a good hand plane. |
#3 posted 1004 days ago |
#4 posted 1004 days ago |
You can probably get one side very close to flat with a hand planer, either manual or powered. Then run it through your power planer (if you have one) with the almost flat side down to make it perfectly flat on the other side. Then flip it and make the almost flat side perfectly flat. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#5 posted 1004 days ago |
hand plane |
#6 posted 1004 days ago |
If you have a good fence and blade, you can joint on the table saw. That is what I did until I bought a jointer a year or so ago. Others tell me that you can joint on the router table or with a router on a straight edge. I have seen on line and in books where people build a sled to plane over sized wood with a router attached to the sled. It would get it pretty close and then they either hand planed or sanded the marks out. I have not done a great deal with hand planes but that is how people did it for thousands of years. Domer |
#7 posted 1004 days ago |
Milo – you can joint only 6” of that wide board. so you’d have half a board surfaced flat – then double stick that to a flat strip of 6” plywood or other flat board, and run that through your planes to get the top flat and parallel. then take the double stuck board off, flip your wide board on it’s now 12” flat surface, and using your planer, finish it off on the 1/2 jointed face to fully thickness and flatten it. joint edge, and call it a day ;) -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#8 posted 1004 days ago |
Another idea that has not been mentioned is rip the board to 6”, joint them and glue them back together if you need boards this width. I prefer to work with boards 6” or less anyway to minimize the potential for cupping. -- Challenges are what make life interesting; overcoming them is what makes life meaningful- Joshua Marine |
#9 posted 1004 days ago |
PurpLev, Not exactly sure what you mean by doublestick. Do you using sacrificial sticks on the edges of the board? Scott, interesting idea… I’ll have to remember that. Domer, I meant jointing the flats, not the edge. Thank you all for the great suggestions. I really want to flatten these 12” boards, and I appreciate the help. Milo -- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear... |
#10 posted 1001 days ago |
I think a router sled will make quick work of it. It’s alot easier end more acurate than muscling a big board threw a jointer. Good luck |
| Forum | Topics |
Woodworking Skill Share
8790 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1529 |
3547 |
15767 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6155 |
