Buying a sawmill to cut my own boards?
« back to CNC Woodworking forum
Forum topic by MassWood posted 01-02-2017 02:52 PM 1435 views 0 times favorited 13 replies Add to Favorites Watch
View MassWood's profile
MassWood
2 posts in 656 days
01-02-2017 02:52 PM
Topic tags/keywords: cnc router
I have a question. I bought a small cnc router and was thinking about buying a small portable sawmill to make my own boards. Can I just make my own boards and then use them on my cnc router table right away? Or do I have to cut the trees down and then wait for them to dry out before using them?
Thanks in advance for your responses
13 replies so far
View Monte Pittman's profile
Monte Pittman
29876 posts in 2484 days
#1 posted 01-02-2017 03:02 PM
Drying is essential. If no kiln is available, then you may need to dry and couple years. Sawmills are awesome if you put in the work for the wood.
Welcome to Lumberjocks
View HorizontalMike's profile
HorizontalMike
7770 posts in 3060 days
#2 posted 01-02-2017 03:26 PM
+10 on Monte’s comment about putting in the work (and time). Milling your own lumber requires:
  • Time
  • Lots of storage space
  • Endless patience
  • A free or nearly free source of fallen trees/lumber to mill
  • Adequate transportation to haul un-milled lumber (truck, trailer, and possibly a truck mounted hoist that can handle the excessive weight)
I am in my mid-sixties so the above IS NOT on my agenda, however if you are a young pup and full of energy then go for it.
MassWood
2 posts in 656 days
#3 posted 01-02-2017 03:27 PM
Thank you
View Kirk650's profile
Kirk650
566 posts in 894 days
#4 posted 01-02-2017 03:55 PM
It’s better to find someone with the small sawmill than to buy your own. You’ll want them to use a sharp new bandsaw type blade. Dull ones wander through the wood. And what Horizontalmike says is dead on.
View HerbC's profile
HerbC
1790 posts in 3005 days
#5 posted 01-02-2017 03:58 PM
You do not leave the logs unmilled to allow them to “dry” or “season” because there will be very little drying when they are in log form. You mill the logs into lumber, then stack the lumber properly for drying, using stick for spacers between each layer of boards. The stack should be in an area that gets good airflow. Drying inside a closed building is not good. Drying under a roof such as a pole barn or open sided shed would be good. Air drying is generally a good process that takes some time, depending on your location and climate and the thickness of your lumber and many other factors. You can speed things up by using a kiln. You can build your own solar kiln or use a dehumidifier to remove the moisture. You can pay someone who has a commercial quality kiln to dry the lumber for you. Bottom line, there’s a lot to learn to be successful converting trees to logs to lumber.
Good luck and …
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View Ger21's profile
Ger21
1075 posts in 3277 days
#6 posted 01-02-2017 06:32 PM
If you have a bandsaw, you can cut smaller logs with that, but you’ll still be waiting at least a year for boards to air dry. If they are thicker than 1”, than it’ll take even longer.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
HorizontalMike
#7 posted 01-02-2017 06:40 PM
As Gerry states above about resawing with your bandsaw. You can make a small sled for resawing short boards less than 24” or so, because even at that length these short logs are really heavy. However, at this scale resawing is very doable and rewarding.
http://lumberjocks.com/projects/100904
View tomsteve's profile
tomsteve
827 posts in 1365 days
#8 posted 01-02-2017 06:41 PM
good to see ya lookin into it, but theres quite a bit to milling.
also gotta figure out how to move them logs- they aren’t light.
Monte Pittman
#9 posted 01-02-2017 07:48 PM
I have access to a good- sized bobcat to move the big ones. All logs are brought in via logging truck.
tomsteve
#10 posted 01-05-2017 03:39 PM
yup, you need a mill!!! if ya decide youre getting a mill ya might want to head over to forestryforum.com and see what mills them folks are using and ya will probably get some suggestions,too. great group of folks there,too.
- Monte Pittman
View WoodNDust's profile
WoodNDust
228 posts in 2252 days
#11 posted 04-30-2017 07:31 PM
- Monte Pittman
- tomsteve
I know a fella that bought a Harbor Freight mill and built his own timber framed home. It worked great. And the HF price point is also very good.
WoodNDust
#12 posted 04-30-2017 07:32 PM
- HorizontalMike
Very true, HorizontalMike. And it’s much easier on the back.
View Holbs's profile
Holbs
1959 posts in 2175 days
#13 posted 04-30-2017 09:22 PM
The Rocket Factory on YouTube gives a fantastic one man operation. If you see his series, he talks about real world application of time, money, vehicle, trailer, kiln, milling, etc. Definitely gives me inspiration to do the same in the coming years. Spent a number of hours watching all his videos a couple weekends ago.
View on YouTube
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
