| Forum topic by woodtoyZ | posted 1003 days ago | 875 views | 0 times favorited | 7 replies | ![]() |
1003 days ago |
Hi- -- www.woodtoyZ.com |
7 replies so far
#1 posted 1003 days ago |
Mix any of the powders with Denatured alcohol rather than water. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#2 posted 1003 days ago |
I have recently used the Analine dyes in Denatured Alcohol. The dye went on very easily and evenly. My only word of caution is that if your are in a very warm workshop it will dry very quickly. -- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein |
#3 posted 1003 days ago |
Hi, whatever you use it anyway raise up all blots, especialy pine.I ‘m sure, that quality of wood processing is success. If pine have polish face – that even not some water can’t damage wood. anyway try Alcohol-base and see – what’s up, only own expirience…................ regards & good luck, Alex. -- Rev 22:21 |
#4 posted 1002 days ago |
you could wet the pine with a little water, let the grain raise and sand it flat again. the grain only raises because it was compressed by all the planing and sanding, when it gets wet it goes back to its initial position. or alcohol based tint as suggested, but your surface needs to have a nearly perfect finish because that thing will amplify any scratch or default x 10 |
#5 posted 1002 days ago |
NGR stain or dye -- http://www.niceashplanes.com/ http://www.efcabineture.com/ |
#6 posted 1002 days ago |
Thanks for all of the great ideas. I will grab a few scrap pieces and experiment. It looks like dying wood is not as easy as i thought! -- www.woodtoyZ.com |
#7 posted 1002 days ago |
I made a simple truck for my son just this past week (nothing remotely like the ones you are showing as projects). It needed to be yellow. I mixed several drops of ordinary food coloring with alcohol and put that on. Then covered it all with shellac. It came out with a nice color. I’m not sure how resistant to fading it will be, but in a year or two my son will be done with it so it won’t matter. Food coloring is water based, but it does mix evenly with the alcohol. It will bleed however if not topcoated with shellac. The reason I used alcohol was so that it would not raise the grain and would dry fast. When my son tires of it, I may keep it just to evaluate how long the color lasts. -- Galootish log blog, http://www.timberframe-tools.com |
| Forum | Topics |
Woodworking Skill Share
8784 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1522 |
3542 |
15755 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2833 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
