Need Help on Garage Shop Heater Wiring
Forum topic by Ripper70 posted 01-01-2017 05:41 PM 977 views 0 times favorited 16 replies Add to Favorites Watch
View Ripper70's profile (online now)
Ripper70
1135 posts in 1057 days
01-01-2017 05:41 PM
Hello All,
Happy New Year! It seems that I somehow mistakenly ended up on Santa’s Nice List this year and on Christmas morning found this under the tree:
Now, I’m no electrician so I don’t want to have to hardwire this thing. I’m pretty sure I can wire this with a plug and mount it near my one and only 220v outlet. It looks like this:
Can I use this:
With one of these:
My plan is to heat the shop and just unplug and plug the TS (my only 220v tool) in as is needed. Will this setup be a suitable workaround to the hardwiring option I’m trying to avoid? Any and all advice on this topic is welcomed.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
16 replies so far
View muleskinner's profile
muleskinner
898 posts in 2585 days
#1 posted 01-01-2017 05:56 PM
Not quite scookum enough. You need a 30 amp circuit, #10 wire, 30 amp outlet and plug.
-- Visualize whirled peas
View MrUnix's profile
MrUnix
6948 posts in 2347 days
#2 posted 01-01-2017 06:09 PM
Yup, 6000 Watts @ 240V works out to 25A. What you got ain’t gonna work.
View TheFridge's profile
TheFridge
10351 posts in 1634 days
#3 posted 01-01-2017 06:31 PM
It would work fine with #10 on a 30A ckt with a 6-30 plug and receptacle.
Technically it’s supposed to be sized up to #8 and 40A by a hair (1A) but it’ll work either way.
Ripper70
#4 posted 01-01-2017 06:33 PM
Okay. Here’s the breaker panel:
So, I need #10 wire and a 30A plug? Can I just switch out the 220v receptacle and use the appropriate plug? Will I need to change the plug on the saw also and is that appropriate? Not sure which receptacle/plug combo to use.
TheFridge
#5 posted 01-01-2017 06:48 PM
does it have a fan as well?
Ripper70
#6 posted 01-01-2017 06:52 PM
- TheFridge
Yes. Like this:
Ripper70
#7 posted 01-01-2017 08:04 PM
So, if I swap out the wall outlet with one of these:
And use this plug on the heater and my saw I’ll be good to go?
View IHRedRules's profile
IHRedRules
115 posts in 1624 days
#8 posted 01-01-2017 09:05 PM
By the way it sounds, your best bet is to hire a licensed electrician. No, you cannot just swap the outlet and plug. Your breaker is 20 amp and would need to be replaced with a 30 amp breaker. Also assuming the wire in the wall is less than #10 (since it is a 20 amp circuit, it should be #12), you would need to replace it with #10 wire as well. If it were me, if I had room for another 2 pole breaker in the breaker box, I would just add another circuit.
View DirtyMike's profile
DirtyMike
637 posts in 1050 days
#9 posted 01-01-2017 09:08 PM
is that heater not to be hard wired only? there is a reason you cant use a plug. also do you prefer infrared over convection?
View tacky68's profile
tacky68
81 posts in 1575 days
#10 posted 01-01-2017 09:12 PM
Ripper:
Like the Fridge stated, You should have #8 wire, with a 40 amp breaker to power your heater/fan. The breaker that
you showed in the picture is a 20 amp. That will work for your TS. not your heater. That heater will pull 25 amps,
the breaker is only capable of 20, but not sustained. #8 wire with a 40 amp breaker is better than #10 wire with
a 30 amp breaker, to give a bigger margin on startup ( so the breaker does not constantly trip due to overload).
Remember: Volts push. Amps pull.
Good luck. Tim.
Ripper70
#11 posted 01-01-2017 09:13 PM
- IHRedRules
Aw, shoot. I had this line installed this past summer and figured it’d be all I needed. Cost me $600 bucks!
- DirtyMike
I’m certain that I’ve read/seen this exact heater installed with a plug rather than hardwired.
View JCamp's profile
JCamp
819 posts in 699 days
#12 posted 01-01-2017 09:36 PM
Here’s my 2cents… I’m pretty tight so to me I’d never pay someone $600 to do the job. If I was u I’d take pictures of what u hav an get a estimate of how many feet of wire u need an go to a friendly local electric shop. The service ppl there will b able to tell u what all u need to do the right. They’ll know what u need to do it an can tell u how to do it After that if u are still uncomfortable with doing it ask them if they know anyone that can do the work cheap. One of them may do that stuff on the side or hav a friend/relative that does it. Good luck
-- Whatsoever thy hand findeth to do, do it with all thy might
View WhyMe's profile
WhyMe
1053 posts in 1709 days
#13 posted 01-01-2017 11:53 PM
That heater is to be hardwired. Did you not read the instructions? If using Romex you need #8 for 40A. If using THHN in conduit you can use #10 for 35A. Also you only need 3 wires, 2 hots and a ground, a neutral is not needed.
View RichmanNot's profile
RichmanNot
39 posts in 659 days
#14 posted 01-02-2017 12:05 AM
One would ask should this be done by a novice? The answer is HELL NO! Everyone is right here you should get an electrician (you need a friend who is a “sparky”) And I agree that it should be hardwired or at least have a separate disconnect switch. Plugging and unplugging while the receptacle is “hot” may cause some arching or worse yet kill you!
MY 2 CENTS = If you paid $600.00 to run a 20 Amp circuit for your 220 volt Table saw… you paid too much unless it was a lot of wiring involved!
-- "can't died in the poor house" (Because he always went around saying... "I can't")
View mrbob's profile
mrbob
182 posts in 717 days
#15 posted 01-02-2017 01:09 AM
Electricity is a balance, load, then outlet specs then wire diameter, and breaker size. Anything to small for the load, is a weak link on the chain, and you could have a fire that could destroy your whole house.
