Hollowing tool advice
Forum topic by groy87 posted 08-19-2010 08:12 PM 1031 views 0 times favorited 3 replies Add to Favorites Watch
View groy87's profile
groy87
136 posts in 2743 days
08-19-2010 08:12 PM
Topic tags/keywords: question lathe carving tool turning
Hello all.
After seeing the amazing work on LJ I have decided to try my hand at hollow forms. The only thing is that I have no idea which of the many available tools I should get. I have a jet mini lathe so I will most likely be doing small to medium size projects (max 8” dia) and since I am working on my masters I currently have a limited budget :/. Any advice on which tools I should look into or what I should look for when buying a tool would be greatly appreciated!
Thanks,
GR
3 replies so far
View Chris 's profile
Chris
1879 posts in 3895 days
#1 posted 08-19-2010 08:38 PM
I use the Kelton hollowing tools. The tools and the handles are sold separate. I have used these for a few years and find the comfortable and easy to use.
This is a link to all kinds of hollowing tools at Wood Turners Catalog AKA Craft Supplies USA
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
View Roper's profile
Roper
1384 posts in 3617 days
#2 posted 08-19-2010 08:54 PM
I also use the kelton system and like it. But if you are trying to save money you should buy Dave Ellsworths new book, it has a whole section on making hollowing tools. I just made a new set and with the steel roll and cutter heads i spent about $35 for both, then i used some scrap wood for handles.
-- Roper - Master of sawdust- www.roperwoodturning.com
groy87
#3 posted 08-20-2010 02:56 PM
Roper: Thank you for recommending Dave Ellsworth’s new book. Sadly I have been unable to find it at the local stores. Would you be able to post an image of your tools with a brief description on how you made them? I would really appreciate any help I can get.
Thanks
-GR
