Trying to beat out the Polar Vortex with RMAX garage door insulation
Forum topic by Holbs posted 01-01-2017 02:50 AM 1326 views 0 times favorited 8 replies Add to Favorites Watch
View Holbs's profile
Holbs
1959 posts in 2173 days
01-01-2017 02:50 AM
Friendly reminder for those with garages: insulate those doors!
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
8 replies so far
View TheTurtleCarpenter's profile
TheTurtleCarpenter
1052 posts in 1210 days
#1 posted 01-01-2017 03:08 AM
I insulated mine 2 weeks ago Holbs. I bought the kit from Overhead door Co. Huge difference !
-- "Tying shoelaces was way harder than learning to Whistle"
View DirtyMike's profile
DirtyMike
637 posts in 1046 days
#2 posted 01-01-2017 03:37 AM
holbs , did you use 2 pieces per panel and squeeze them together?
Holbs
#3 posted 01-01-2017 03:42 AM
Yep Mike. I couldn’t figure out how to slightly bend the sheets. I tried :) I saw other you tube videos of folks cutting 5 or 6 notches so it bends. I just figured faster and more efficient to just cut in half, angle one piece up, angle another down to make a shallow “V” and push the center flat. Worked like a charm.
View johnstoneb's profile
johnstoneb
3011 posts in 2316 days
#4 posted 01-01-2017 03:47 AM
My door had a deeper grove at the top so cut to fit pushed it up into top groove then slid down slightly into bottom. I really make a difference on heat retention. Did have to tighten the door spring slightly.
-- Bruce, Boise, ID
View Paul M's profile
Paul M
117 posts in 1447 days
#5 posted 01-01-2017 03:48 AM
just an fyi that I have seen several garage doors with homeowner installed insulation rust out very quickly. The insulation seems to be trapping alot of moisture. It seems most prevalent on garages with a southern exposure. I don’t know the best way to prevent.
-- Paul M
DirtyMike
#6 posted 01-01-2017 03:50 AM
Yep Mike. I couldn t figure out how to slightly bend the sheets. I tried :) I saw other you tube videos of folks cutting 5 or 6 notches so it bends. I just figured faster and more efficient to just cut in half, angle one piece up, angle another down to make a shallow “V” and push the center flat. Worked like a charm.
- Holbs
Great idea, my door panels are taller than standard so i will have to make my own. great tip
Holbs
#7 posted 01-01-2017 03:59 AM
Paul, I thought about rust & condensation. Some other installations used construction glue or sealed up everything using “Great Stuff” expanding foam. I used neither. My garage door panels are raised inward a bit. This does not create a flat surface for the rigid foam to lay against, giving ample space of hopefully enough air flow. If worse came to worse, I could remove the foam panels and toss in one of those anti-condensation bags or something :)
View Rich's profile
Rich
3650 posts in 733 days
#8 posted 01-01-2017 05:16 AM
I just replaced the 20 year-old door on the house I moved in to. The old one shook and rattled and I constantly feared it would come out of the tracks.
I went with the max insulated door they offered. The Liftmaster has WiFi so I can check the status and open it or close it from across the country. Pretty cool.
There’s a problem though. It’s so quiet that I can’t hear my wife’s arrival.
