Boxing Question
Forum topic by Cheapguy82 posted 12-30-2016 09:40 PM 932 views 0 times favorited 22 replies Add to Favorites Watch
View Cheapguy82's profile
Cheapguy82
74 posts in 587 days
12-30-2016 09:40 PM
Topic tags/keywords: box maple cherry plywood felt
All the boxers out there -
What do you use for the bottoms of your nice boxes? Solid wood that has been milled down to a reasonable size? Plywood that gets covered? Other suggestions?
I’m making a box out of curly maple and cherry and have enough wood to make the bottom out of the curly (if I mill it down), but I could use ply and cover it in felt inside and out and not see the piece of curly maple turned mostly into sawdust since I don’t have a way to mill down a board of its width.
I have seen that some of you make very VERY nice high end boxes and got wondering what you use since the bottom is never shown in pics or described.
Thanks for the guidance and expertise!
Stephen
-- Stephen - Georgia
22 replies so far
View turnkey47's profile
turnkey47
277 posts in 2745 days
#1 posted 12-30-2016 10:15 PM
i use plywood and cover with fabric
View Blackie_'s profile
Blackie_
4883 posts in 2566 days
#2 posted 12-31-2016 12:51 AM
1/4” ply board I think it’s realistically 3/16”. If I’m just making a traditional miter joint box, most of my boxes are hybrids mine own design which starts out as a bandsaw box.
Measure up 1/4” from the bottom and cut your dados, if you’re building a box joint box than you have to add stops to your router fense as you don’t want to cut all the way through as it will show a gap in the sidewalks of your box exposed from the outside.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
View Aj2's profile
Aj2
1501 posts in 1851 days
#3 posted 12-31-2016 01:17 AM
I use solid wood.I put a lot of craftsman ship into my boxes.
Sometime I use all the same wood sometimes a different wood with a nice aroma.Like white oak or cedar of Lebanon.
Let me know if you want to see one of my badass boxes.
Aj
-- Aj
View Dan's profile
Dan
714 posts in 1945 days
#4 posted 12-31-2016 01:33 AM
Aj2..”Let me know if you want to see one of my badass boxes.”
Aj, I looked at the one box you posted and it was badass,no doubt about it. For some reason it didn’t get in the top three.
Cheapguy, To add more weight to some of my lighter boxes, like maple, I’ve started using Ipe for the bottom. It gives the box a feeling of quality or substance. Ipe is a very dense and heavy wood.
-- Dan
View JADobson's profile
JADobson
1100 posts in 2164 days
#5 posted 12-31-2016 01:37 AM
I’ve used fabric over solid wood, felt on plywood, and bare solid wood. I like the fabric over wood best so far. You can see a few examples in my projects.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
View shipwright's profile
shipwright
8006 posts in 2851 days
#6 posted 12-31-2016 02:38 AM
I prefer good plywood for its dimensional stability. If it will be seen I veneer it with something nice. If it will be lined, likely not.
View Aj2's profile
Aj2
#7 posted 12-31-2016 03:02 AM
Aj, I looked at the one box you posted and it was badass,no doubt about it. For some reason it didn t get in the top three.
Cheapguy, To add more weight to some of my lighter boxes, like maple, I ve started using Ipe for the bottom. It gives the box a feeling of quality or substance. Ipe is a very dense and heavy wood.
Oh yeah I like seeing others craftsmanship what you got?
- DanielP
-- Aj
View Dan's profile
Dan
#8 posted 12-31-2016 03:18 AM
- DanielP
- Aj2
Excuse me?
-- Dan
View Aj2's profile
Aj2
#9 posted 12-31-2016 03:58 AM
@Dan I though you might have some nice boxes you wouldn’t mind sharing.
My bad
Aj
-- Aj
View Dan's profile
Dan
#10 posted 12-31-2016 04:10 AM
No prob, I was complimenting your box making skill and taking a jab at LJ’s rating system. I can see where my words could be misinterpreted. You should post more boxes, not me.
-- Dan
Cheapguy82
#11 posted 12-31-2016 11:26 AM
Thank you to hose who have posted responses so far. I really respect the work that I’ve seen on here and the opinions of you, who are obviously more experienced than am I.
I’d still love to hear more opinions about it as long as people will still share!
I think that I’m leaning toward making the box’s bottom with plywood and either line the outer facing side with the same material that I will be using on the inside or leave it uncovered (I have some plywood that has a reddish tint to it, so even if someone looks at the bottom, they probably won’t notice to much). Since I don’t have a way to mill my maple down without wasting most of it (using my planer to turn a 4/4 piece that would be a reasonable size for a box whose height is going to be about 4” in all), I just can’t bring myself to do it. I think that I can put that wood into better use some where else.
View MontanaBob's profile
MontanaBob
831 posts in 2737 days
#12 posted 12-31-2016 11:53 AM
Mdf, fabric or leather lining.
View Dan's profile
Dan
#13 posted 12-31-2016 01:31 PM
I guess the obvious question is if you have a table saw why not just re-saw the piece.
-- Dan
Cheapguy82
#14 posted 12-31-2016 01:58 PM
The blade on my table saw can cut a piece about 3” – 3.5” thick…maybe a bit more. The shortest dimension of the base piece for my box is a little over 9”, so even if I flip it I can’t cut it all the way through on my table saw.
...and I don’t own a band saw…or else this would be a non issue for me.
View bold1's profile
bold1
294 posts in 1900 days
#15 posted 12-31-2016 02:15 PM
Most of the boxes I’ve made have been Bass wood & I have used it all the way round. But I usually cover the bottom with felt so the box will not scratch if it’s slid on the top of a dresser or table. I just glue it fast and trim after dry with a pair of curved embroidery scissors.
