Need tips for sharpening carbide jointer knives
Forum topic by jwb96 posted 12-30-2016 08:04 PM 772 views 0 times favorited 4 replies Add to Favorites Watch
View jwb96's profile
jwb96
6 posts in 927 days
12-30-2016 08:04 PM
Topic tags/keywords: jointer sharpening question
I picked up an old Makita 2020 8” jointer and am in the process of getting the knives into better shape. After getting them out, I realized they are carbide tipped. I could just send them off to the sharpening service, but I figure at $32 pre sharpening, I might as well pick up a diamond stone and do it myself.
I made a jig to hold them at the right angle. My question is, should I get a 10” or larger stone so that the entire cutting edge can be against the stone at all times, or could I get away with a 6” or even a 4” stone and just run the stone down the knives in the jig and still ensure straight, parallel edges?
Or, is there a better solution all together?
Thanks,
Jim
View AlaskaGuy's profile
AlaskaGuy
5000 posts in 2549 days
#1 posted 12-30-2016 08:27 PM
Send them out to someone who has the proper equipment.
View Aj2's profile
Aj2
1953 posts in 2038 days
#2 posted 12-30-2016 08:34 PM
I used to touch up the carbide knives in my 735 planer.I used a smith diamond thingy.I will not get out big nicks but brings back a good edge.
-- Aj
View ArtMann's profile
ArtMann
1220 posts in 1056 days
#3 posted 12-30-2016 08:51 PM
You will definitely need to buy a stone that will allow the knife edges to remain in contact with the abrasive surface at all times and provide a long continuous stroke. You will also need a diamond abrasive to cut the carbide. Anything less won’t do anything except wear you out. You will also need a very precise jig to hold the knife at the right angle at all times. That is more challenging than you might think. My honest opinion is that you should either send the knives to a sharpening service that is set up to grind carbide or just buy some high speed steel replacement knives that are much easier to sharpen. Before I went to a segmented spiral cutter head, I used to use a sheet of plate glass and a Dulen jig to sharpen high speed steel knives. Here is a link.
http://www.deulentools.com/BuySharpeners.html
ArtMann
#4 posted 12-30-2016 08:54 PM
