Finish for shop use
Forum topic by Aaron McCain posted 08-18-2010 06:08 PM 1166 views 0 times favorited 8 replies Add to Favorites Watch
View Aaron McCain's profile
Aaron McCain
125 posts in 2806 days
08-18-2010 06:08 PM
Topic tags/keywords: question beech finishing
I am in the process of finishing up my new work table. The working surface is two layers of 3/4-inch MDF with a exchangeable 1/4-inch hardboard surface. I am trimming the table surface with European Beech which I’ve learned is pretty hard and will be a good durable edge for quite awhile.
I’m looking for recommendations on how to protect the wood. What type of finish should I use?
8 replies so far
View Greedo's profile
Greedo
473 posts in 2928 days
#1 posted 08-18-2010 08:12 PM
i use linseed oil mixed with turpentine, or BLO, on my worksurfaces.
it doesn’t protect against scratches knocks or anything, what it does is keep the materials properties (not turning it into plastic like poly or varnisch would) while rendering it almost impermeable to glue or paint drops. they are cleaned off easily.
one other advantage is that when theres dried up glue, scratches or stains on it, you can go over it with a verry fine grit sandpaper with the ROS, and re-apply a coat of BLO. the surface is back as good as new and inmediately usable.
View Div's profile
Div
1653 posts in 2907 days
#2 posted 08-18-2010 08:57 PM
I’m with Greedo, BLO is the way to go.
-- Div @ the bottom end of Africa. "A woodworker's sharpest tool should be his mind."
View Dan Lyke's profile
Dan Lyke
1519 posts in 4092 days
#3 posted 08-18-2010 10:17 PM
I was gonna pop in here to say that for heavy duty surfaces, I like the water based floor polyurethane that I’ve been getting from the local paint store that has warnings against direct skin contact while it’s wet, but it’s really hard to keep it flat, which I think is important in a workbench.
So, yeah, sounds like these other guys have better advice than me.
Aaron McCain
#4 posted 08-18-2010 11:15 PM
I am new to the whole finishing game, so please forgive a basic follow up question. I have a product by Watco labeled “Danish Oil Finish”. How does that differ from BLO?
View CloseShave's profile
CloseShave
5 posts in 2820 days
#5 posted 08-18-2010 11:42 PM
I made my assembly table a torsion box with MDF skins. The edge was trimmed with some maple I had around. I finished it with 3 coats of oil based polyurethane. I didn’t use the water based poly b/c I was told it would absorb into the MDF and distort it. I can believe this b/c MDF is sensitive to water. The oil based poly worked great, light sanding w/220 between coats. Take a look at the pictures of my shop, there’s a shot of the bench top.
Greedo
#6 posted 08-19-2010 07:41 AM
i don’t know danish oil here, but according to wikipedia it’s sort of the same. it’s a polymerised oil.
i make my own mix by mixing 50/50 linseed oil with thurpentine oil, it’s quite cheap that way and natural.
thurpentine is just distillated woodsap, it protects the wood from fungus and other bad stuff, and without it the linseed oil wouldn’t dry.
@ closeshaven i use acrylic varnish on mdf and for some reason it doesn’t distort or inflates the mdf, it could be the same with waterbased poly?
View docholladay's profile
docholladay
1287 posts in 3026 days
#7 posted 08-19-2010 08:37 AM
Boiled Linseed Oil, Tung Oil, Danish Oil, as well as some others, are all curing oils extracted from various plants. As a general rule, this type of finish will seal the surface and prevent things like glues and paints from penetrating the surface, but they will offer very little in the way of buildup and thus protection against scratches and dings in the surface. However, this is a work surface and it is made of mdf. All you need is something that helps to keep your glue up projects and such as that from sticking to the work surface and things like that. It’s not like your trying to create a french polish finish. It’s going to get dings and scratches, if you use it. That’s what it is there for.
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
View hObOmOnk's profile
hObOmOnk
1381 posts in 4095 days
#8 posted 08-19-2010 12:20 PM
Properly applied, BLO will cure without being diluted with solvents.
Danish Oil isn’t oil. It’s a product that contains oil, and in most cases, only a small amount of oil.
Watco brand Danish Oil is diluted with about 75% solvents, and is a mixture of raw linseed oil, other oils, resin and gilsonite. It is not designed for building a protective finish.
-- 温故知新
