Drilling in tight spaces
Forum topic by groland posted 08-18-2010 05:48 PM 13198 views 0 times favorited 9 replies Add to Favorites Watch
View groland's profile
groland
185 posts in 3440 days
08-18-2010 05:48 PM
What are my options for drilling holes in tight inside corners?
I am working on a project installing cleats inside a cabinet, and I need to be able to drill pilot holes about 3/4 inch each way from the inside corners. My (standard electric drill is WAY too big. What can I do? Tools/adapters for this?
Thanks,
George
9 replies so far
View Gregn's profile
Gregn
1642 posts in 3012 days
#1 posted 08-18-2010 06:03 PM
You need a right angle drill attachment or use a Dremmel tool.
View Rick's profile
Rick
9731 posts in 3061 days
#2 posted 08-21-2010 10:48 AM
I Have a 6” or 8” Flexible Shaft that I use for situations like yours.
One end in the Drill Chuck and the other end has a Female Hex Socket. I have a couple of Drill Chucks that have a Male Hex end that “Plugs In” to the Extender. I think they are available at most Big Box Stores.
I also have a Right Angle Drive attachment for the drill but I don’t think mine would let you get 3/4” from the Corners. Maybe Just!!
Rick
-- LIFE is what happens when you're planning on doing Other Things!
View Catspaw's profile
Catspaw
236 posts in 3843 days
#3 posted 08-21-2010 12:37 PM
I have the Milescraft attachment. Less than $20. It’s as narrow as any I’ve seen. Takes two hands…one to hold the head in position. This can be fun in a narrow space.
You need to have the hex shaft drill bits that will slip right in. Then you have to figure out how to get the bits out ‘cause it’s a magnetic hex socket. Usually not enough to pull the bit out if it gets tight.
But, considering some of the places I’ve had to drill and screw in, it works very well.
-- arborial reconfiguration specialist
View ChefHDAN's profile
ChefHDAN
1067 posts in 2878 days
#4 posted 08-21-2010 12:55 PM
I just happened to pas a Harbor Freight store while on a business trip and had time to stop in and picked this up; http://www.harborfreight.com/power-tools/drills/3-8-eighth-inch-close-quarters-drill-with-keyless-chuck-95877.html
I found myself in the same problem 3 weeks ago, and wished I had one of these, I managed to get around my dilemma using a 1/8” collet in a mini die grinder with my air compressor, and then a bit set with an air ratchet to drive the screws. I got it done but DAMN, was it loud in that cabinet. Havent tried out the HF drill yet but for $40 it seems very good, even came with a set of replacment brushes
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3143 days
#5 posted 08-21-2010 12:59 PM
some of the small screwdriver machines like that ixo from Borch and hex shaft drill bits
can do the job if its only a few holes
View richgreer's profile
richgreer
4541 posts in 3103 days
#6 posted 08-21-2010 04:11 PM
Here’s the expensive solution – -
http://festools-online.com/index.php/festool-tools/festool-drill-drivers-accessories/festool-drill-drivers/festool-cordless-drill-t-12-4.html
Dennisgrosen
#7 posted 08-21-2010 05:26 PM
yaaaah Rich but what a dream to use when you set up and deliver kitchens in kits
if you have one of those its going to bee the most importen workhorse in the toolbox
View hObOmOnk's profile
hObOmOnk
1381 posts in 4156 days
#8 posted 08-21-2010 06:10 PM
Lee Valley
-- 温故知新
Rick Dennington
5912 posts in 3222 days
#9 posted 08-21-2010 07:46 PM
Greetings groland,
Why don’t you drill the holes BEFORE you install the cleats? You already know that they are going to be 3/4’ from the ends, so measure the length of the cleats, glue or screw them in, OR allow youself enough room to get a drill in there to screw them in…...... piece of cake…..............Maybe glue, and a nailgun.works for me…
