MDF splitting
Forum topic by Walt posted 08-18-2010 04:52 PM 1956 views 1 time favorited 8 replies Add to Favorites Watch
View Walt's profile
Walt
246 posts in 2834 days
08-18-2010 04:52 PM
I have been building a shop table project that has MDF as a frame. The plans called for butt joint, screwed and glued but even though I predrilled and used wax on the screws I still had some splitting of the end of the MDF piece. Is there a good way to prevent this
Walt447
-- Walt Wilmington Delaware, http://waltlumley@yahoo.com
8 replies so far
View Bill White's profile
Bill White
4929 posts in 3956 days
#1 posted 08-18-2010 04:55 PM
The short answer is NO. It is just the nature of the beast.
Bill
-- bill@magraphics.us
View wseand's profile
wseand
2796 posts in 3037 days
#2 posted 08-18-2010 05:02 PM
Walt like Bill said it is what it is. Can you do a Dado on this project and Glue and nail it. Either that or some sort of cleat.
View Keith Fenton's profile
Keith Fenton
328 posts in 2915 days
#3 posted 08-18-2010 05:04 PM
Like Bill said, it will happen. To minimize splitting I predrill with a big enough bit (slightly bigger than normal), keep screws more than 3” away from the end of the sheet, keep the screws over 6” apart and don’t screw them in overly tight. IMO screws don’t accomplish all that much in MDF and I basically only use a minimal amount of screws to help with assembly and gluing.
-- Scroll saw patterns @ http://www.sheilalandrydesigns.com
View jimp's profile
jimp
208 posts in 3756 days
#4 posted 08-18-2010 05:38 PM
When screwing into the end of MDF, use confirmat screws. They are designed for MDF. Here is some information on confirmat screws from Mcfeely's.
I also agree with SCROLL3R about staying away from the end of the sheet. The confirmat screws will help a lot.
-- - Jim, Carroll, OH
View Walt's profile
Walt
#5 posted 08-18-2010 06:11 PM
Boy am I suprised to get answers this quick. Thanks. The way I handled these cracks was to fill them with epoxy and clamp them tight. The next day every thing was tight and square. The repair is very noticable but I will be covering it with plywood for a shelf so no one will know :)
View Ger21's profile
Ger21
1074 posts in 3126 days
#6 posted 08-19-2010 04:05 AM
If it splits, your predrilled hole is too small. However, a better method is to use a shallow dado, maybe 1/8” or even slightly less. This will keep the board from splitting.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View jusfine's profile
jusfine
2422 posts in 2921 days
#7 posted 08-19-2010 04:45 AM
I have drilled holes in the edge of the MDF (where I had to fasten close to an end or edge) with a 3/8 brad point bit, glued and inserted a 3/8 dowel, marked the location, then predrill and place your screws into the dowel, and it will hold and not split…
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Walt's profile
Walt
#8 posted 08-19-2010 02:00 PM
Thanks for all the good information. The project I am working on calls for a rail to hang a bench slave system using dowels to hold material against the from of the table. The plans call for MDF for this rail system but I am switchiing it to 3/4 inch oak since it will be under some stress.
