Adjusting sled runners.
Forum topic by Carloz posted 12-30-2016 05:39 AM 510 views 0 times favorited 5 replies Add to Favorites Watch
View Carloz's profile
Carloz
1147 posts in 740 days
12-30-2016 05:39 AM
Did anyone try to use teflon screws or something similar to adjust diy sled runners? Mine either get stuck in the slots or are too loose depending if it rains outside.
5 replies so far
View Rich's profile (online now)
Rich
3666 posts in 737 days
#1 posted 12-30-2016 06:08 AM
That’s a problem. Reminds me of my experience where two wrongs did make a right. I had build a crosscut sled for small pieces. It was about .0014 inches per inch off square. I was OK with that since they were short cuts, but the sled was super tight, so I used my rabbeting plane to take some width off the runners. I screwed up, and got it too loose.
It worked out though, since, by keeping the sled twisted left, the error went down to nearly zero. I drew a reminder on the fence to keep it torqued that way and never looked back.
Sorry that doesn’t help your situation. If it’s that bad, you might want to invest a few bucks in metal runners that are adjustable.
View Woodknack's profile
Woodknack
12369 posts in 2528 days
#2 posted 12-30-2016 06:51 AM
Yeah if rain is affecting them that much I would switch to steel or plastic. I use both wood and plastic. You might try putting a coat or two of polyurethane on the wood runners, sanding it smooth with 320 or 400, and seeing if that helps.
View OSB's profile
OSB
147 posts in 674 days
#3 posted 12-30-2016 08:28 AM
I haven’t had that problem yet but preparing to align the saw blade on my project saw restoration, I ordered a Microjig Zero play bar set.
They are plastic to resist environmental factors, adjustable width for a custom fit to your miter slot and have a second set of threads so you can square your sled to the table without losing the slot width adjustment.
The first job for mine is to attach it to some wood and then hang a dial indicator off that for blade alignment. The zero play adjustment will give me a very repeatable and accurate result so I should be able to dial in the blade within 0.0005” of parallel to the miter slots.
View jerryminer's profile
jerryminer
944 posts in 1590 days
#4 posted 12-30-2016 08:28 AM
I stopped using solid wood for runners. The last couple of sleds I made, I used baltic birch ply for the runners. they are holding up well, and don’t change dimension with weather changes.
View Redoak49's profile
Redoak49
3531 posts in 2137 days
#5 posted 12-30-2016 11:52 AM
I have made the runners from lots of materials and always spent a lot of time fixing them. I now use the Incra miter sliders and the fit is easy.
When I have to make a new sled, I take the miter sliders off the old one and put them on the new one.
