| Forum topic by CovenantCreations | posted 1008 days ago | 3285 views | 0 times favorited | 12 replies | ![]() |
1008 days ago |
Ok, this isn’t really a skill share, but I didnt know where else to put it. I am looking of r a way to soundproof the wall between my new workshop (24×24) garage which is attached to our house. I plan on insulating the wall very well and sheetrocking it. But then I goth this idea, and I dont know if it would work or not thats why I am on here asking. Putting up some sort of metal siding on the wall, such as what they use for siding buildings and such. I have a ton of the galvanized stuff laying around form old sheds I tore down, and I was thinking this may deflect the sound back into the room. Maybe not? Whats your say on this? |
12 replies so far
#1 posted 1008 days ago |
If you are thinking about putting the steel up on the wall against the house, I would think a sound deading insullation, and certainly regular insulation would work better. I would think steel would reflect the sound both ways and possibly cause vibrations. My shop is the same size as yours and it has a wall against the house also. I used regular insulation. Instead of sheetrock, I insulated the wall, then put 3/4 inch plywood on the wall, covered by 1/2 inch pine beaded paneling. This worked well to deaden the sound and looks nice. I put the plywood and paneling around the entire room so I could just screw cabinets and shelves anywhere with out using anchors or hitting studs. You can see it in my shop pictures. -- Wayne - Plymouth MN |
#2 posted 1008 days ago |
First, building code requires a fire barrier between the garage and the house (I imagine your shop qualifies as a ‘garage’ in the code), which means a fire-rated drywall, usually 5/8” with taped seams. You can put plywood or other flammable materials over this (I think). There are things called sound isolation channels that are designed to space the drywall away from the studs and to minimize sound transmission. If it was me (my shop is in the basement), I’d insulate, sound isolation channels, fire rated drywall, decorative mounting surface (plywood, beadboard, etc.). |
#3 posted 1008 days ago |
I needed to soundproof my daughters upstairs bedroom from my upstairs tenants kitchen in my 110 year old home. The upstairs tenants happen to be rock musicians. They don’t do alot of practicing while home out of respect to me and my 3 year old, but they do sometimes. I found a sound absorbing drywall called quiet rock from quiet solutions. It is absolutely amazing stuff. I only used it on the 2 common wall between rooms. To try to really sound proof the room I used a combination of homasote and quiet rock over existing drywall. My daughters room has become the quietest room in the house. Even during loud practice with heavy bass it works amazingly. The bad news is it is expensive and it is amazingly heavy. If you need just a couple of wall this is the way to go. Mike Holmes from Holmes on homes, the Canadian DIY show actually used it on an episode once. -- Strati Alepidis, Somerville, Ma, Member Red Sox nation |
#4 posted 1008 days ago |
Ironically after I wrote this post and entered it, I noticed an ad for Quiet Rock at the bottom of the screen. -- Strati Alepidis, Somerville, Ma, Member Red Sox nation |
#5 posted 1008 days ago |
Anyone ever use corkboard to absorb sound? Thanks for all the input so far. |
#6 posted 1007 days ago |
Metal would resonate making the noise worse. The problem is sound will find any little hole and flow thru it. So if you don’t insulate all 4 walls and the ceiling it won’t do much. That said… Mass would be the cheapest, easiest, and most effective method to reduce noise. Double drywall the adjoining wall will add a bit of noise blocking. Squirting some green glue in between the layers will help a bit more for a bit more cost. The quietrock would cost a lot more but do quite a bit more sound blocking. You could go farther but the law of diminishing returns makes it impractical without doing more total enclosing of the sound. Just keep in mind the loud noises of certain tools (planer, table saw, belt sander etc) makes it nearly impossible to be ‘sound proof’ you can only lower the volume of the noise getting thru with increasing levels of cost associated with that. The ultimate would be to build a room within a room with new studs, walls, ceiling and floating floor with 6 inch thick walls that have alternating studs (so the inside and outside drywall don’t share framing members to pass vibrations) with fibreglass weaved between the studs with mass loaded vinyl hanging freely in the cavity with quiet rock on both sides of the wall+ ceiling. With two heavy outside doors with gaskets on all sides to ensure a good air seal in an airlock configuration. Any wall infiltration should be properly gasketed ( lighting, electrical sockets, etc. Ventilation should be fibreglass tubing with multiple 90 degree bends to absorb noise. Obviously the time, money, and space restraints make this slightly impractical. The above is an idealized sound proof room for a home theater, but is applicable to any noise reduction scheme. Parts of the plan can be integrated as time/money/space allows. |
#7 posted 1007 days ago |
Versa is right on the money. I helped build all the studios for CMT downtown Nashville and here is what I learned from the engineers. Sound actually reverberates through solid materials (i.e- concrete, studs, doors). The more dense and solid the more it can carry the sound. Soft materials tend to absorb the sound and not transfer it on to whatever it’s touching. The best thing is to have dead air space in between tweo walls with as little touching as possible in between them. The studio walls were constucted in this order: sound baffle – 5’8” drywall – sound caulking – 5/8” drywall – neopreen (this was a foam tape put on all the studs)- stud – 3” of air space ( then the reverse )- stud – neopreen – drywall – caulk – drywall – sound baffle. This was the order from one studio into the next. You could fire a gun and not hear it in the next one. Of course the floors were built on these super expensive sound absorbing blocks and had 3 layers of drywall then the plywood. In your case I probably just build a new insulated wall an inch or two in front of your existing wall and try not to let them touch. Just passing what I learned. Let us know what you do -- Neil, Middle TN |
#8 posted 1006 days ago |
The soundwave energy that causes materials to vibrate and transmit sound is best reduced when that energy has to pass between materials of different densities and ridgidity. A common way to achieve this is sandwiching a heavy flexible material between two layers of a stiffer material. When the sound hits the outer surface of this “sandwich” the energy is then trying to flex the two stiff sheets whilst the more flexible material in the center absorbs the pressure. They sell a very dense heavy rubberised sheet for this purpose, usually glued between two layers of thick plasterboard, but it is very expensive. Some kind of heavy foam rubber, dense neoprene or similar material is a good replacement, though you would need to be careful about fire regulations. Do a search on the web for diy soundproofing and you will see various differnet ideas and some more in depth explanations opf the theory. I saw a nice diy studio that used tightly rolled up carpet offcuts between double plaserboard floating walls but the guy was hunting in carpet warehouse skips a long time to get all that free material. Good luck! |
#9 posted 1005 days ago |
Some quiet rock was used in a building where I work and it is amazing stuff. It was installed between an office and private bathroom and a common area. No one can hear a thing from the office or bathroom anymore, I have done audio and video recordings in the room so I know this stuff works. The only bad thing is that it the common room has a wireless network and the quiet rock does not let it pass through! |
#10 posted 1005 days ago |
I researched acoustics for 6 years in school and designed recording studios and such for a firm in Berlin for a summer. The thing with room acoustics is that there are a ton of variables, and no single product is going to be your silver bullet, though something like quietrock will come close. One of the oldest, tried and true methods is to simply frame out a second wall that is not mechanically coupled to the wall you want to soundproof. Air is actually one of the best sound insulators we have. So when you have a sound wave that has to go through sheetrock, fiberglass insulation, air, fiberglass insulation, sheetrock and then air again, you have all kinds of sound reduction because of the boundary impedance mismatches. If you want to read more about how to deal with it, I recommend “The Master Handbook of Acoustics” which is only about $30 and written so everyone can understand it. If you were to double wall with double layers of drywall and plenty of insulation inside (but do not completely fill the area between walls) you would see a huge sound reduction. Of course, if you can afford quietrock, it could save you about 4 inches in the width of your shop. And don’t put up the metal, it will reflect back more high frequency energy that will damage hearing quicker. -- Brian T. - Exact science is not an exact science |
#11 posted 1004 days ago |
I needed to sound-proof my office in our house for video work so had a contractor come in who has done this before. He used loose fiberglass insulation in the bays and two layers of an accoustic drywall. I don’t tnhink it was called Quiet Rock but not sure of the name he gave me. Whatever it is, it works great! -- Tom Hintz, www.newwoodworker.com |
#12 posted 1003 days ago |
I had some extra foam sill sealer rolls laying around and stapled it to the edge of the studs prior to drywall. It made a huge difference in the walls that had it. After I ran out of sill sealer, I bought a roll of cheap laminate floor underlayment. The sound transfers through the rigid parts of the wall and you need to isolate those connections. FineHomebuilding had an article on sound deading a couple years ago. -- Tony - Anchorage, Alaska |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3551 |
15788 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6161 |
