On-Off switch for charging valet
Forum topic by DonJ posted 08-17-2010 11:23 PM 1312 views 0 times favorited 3 replies Add to Favorites Watch
View DonJ's profile
DonJ
250 posts in 3525 days
08-17-2010 11:23 PM
Someone built a valet for charging phones. They rewired the power strip so a power switch could be located on the outside of the box. If anyone remembers that person, or knows how to install an in-line on/off switch for a power cord, I sure would appreciate any help. Thanks as always.
Don Johnson
-- Don, San Antonio, TX
3 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3711 days
#1 posted 08-18-2010 04:59 AM
I think Marc Spagnolo has made one check him out http://lumberjocks.com/thewoodwhisperer.
View Gregn's profile
Gregn
1642 posts in 2982 days
#2 posted 08-18-2010 10:39 PM
For my bicycle light battery I bought a timer to plug into so that my battery doesn’t over charge as the battery its self cost a $100.00 to replace. This works well for me and the charger isn’t drawing constant power.
View brtech's profile
brtech
1029 posts in 2921 days
#3 posted 08-26-2010 04:22 PM
Mount a switch in your box some way that the wiring will be protected.
Run the outlet strip power cord near the switch and mark where the cord hits the switch.
Carefully remove the outer insulation of the cord from 1/2” back from the marked point for about 3” without nicking the insulation on the wires inside. You can cut 2/3 of the way through the insulation and tear through the remaining part.
You will see 3 wires: black, white and green. You want the black wire. Cut it 1.5” from the side towards the outlet strip. Strip the insulation 1/2” from both sides of the cut black wire.
Connect the stripped ends to the switch.
Use a P clip or some other way to fasten down the cord so that the wires on the switch are not stressed.
