Spraying water borne poly from a Greco airless sprayer
Forum topic by SweetTea posted 12-29-2016 10:48 AM 1824 views 0 times favorited 4 replies Add to Favorites Watch
View SweetTea's profile
SweetTea
360 posts in 804 days
12-29-2016 10:48 AM
Hey fellas, can anyone tell me if it is ok to spray water borne poly from a Greco airless spray rig? I have a large cabinet build to spray, and I feel more comfortable with an airless sprayer than I do a cup gun. The only air compressor run cup guns that I own are the el cheapo HF units. Which I normally only use for spraying stain. I like to use Polycrillic due to its relatively (for a poly) fast dry times and the durability it provides is excellent.
If you guys give me the go ahead on spraying this water borne poly (polycrillic), what is the best method of cleaning out my Graco spray rig and gun? I was thinking to start by running some water through it, then run some mineral spirits followed by some more water. Does this sound reasonable? Is mineral spirits ok to run through the spray rig and gun afterwards?
5094 posts in 2638 days
#1 posted 12-29-2016 12:18 PM
I don’t own an airless gun, and others may have a better answer: but my suggestion would be to try it and see if you get what you want. I do wonder what you think the MS will do in the cleaning. Soap and water is all that’s normally needed to clean after a waterborne finish has been used.
View JAAune's profile
JAAune
1838 posts in 2461 days
#2 posted 12-29-2016 05:34 PM
I’d ditch the Polycrylic. While it works, it was never my favorite water-based finish. If you pick up something from another supplier (like Kem Aqua Plus from Sherwin Williams), they’ll provide a data sheet listing desirable specs for the application equipment.
Never follow a water rinse with mineral spirits. The two combined make an awful mess. Use denatured alcohol as the transition solvent. To move from Polycrylic to lacquer you’d flush with water, then alcohol and finish with lacquer thinner.
View cracknpop's profile
cracknpop
325 posts in 2493 days
#3 posted 12-29-2016 06:22 PM
Have you tried spraying the poly through your “cup gun”? Try test spraying on a piece of scrap wood and see how it sprays.
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
View john23's profile
john23
1 post in 661 days
#4 posted 12-29-2016 07:05 PM
You didn’t specify what airless,but I would only use an hvlp sprayear. Although it could be done Using a regular airless would put out to much product.
