Citric acid and japanning
« back to Hand Tools forum
Forum topic by DW833 posted 12-29-2016 02:56 AM 770 views 0 times favorited 5 replies Add to Favorites Watch
View DW833's profile
DW833
220 posts in 2058 days
12-29-2016 02:56 AM
Topic tags/keywords: handplane restoration citric acid rust
I purchased a Stanley #4 today. Believe it is a type 11 in really good condition. The best condition #4 I’ve purchased in awhile for $15. The japanning is almost 100% complete and looks great. Usually I have some evaporust and use it to clean the rust. I’m out, but have some citric acid I wanted to try. However, I want to make sure it won’t remove the japanning. Most of the research I’ve done results in the japanning not affected, but do see a few items on LJ and others that the japanning was removed by the acid.
Wanted to know if anyone has experience with the citric acid damaging or removing the japanning.
5 replies so far
View TheFridge's profile
TheFridge
10506 posts in 1662 days
#1 posted 12-29-2016 04:08 AM
Only if there was rust underneath. Make sure to neutralize the parts. I’ve had stuff flash rust rather quickly after forgetting.
View Don W's profile
Don W
18990 posts in 2743 days
#2 posted 12-29-2016 12:04 PM
Plus 1 to What Fridge said
View rwe2156's profile
rwe2156
3134 posts in 1657 days
#3 posted 12-29-2016 02:30 PM
From the sound of it, personally I wouldn’t touch it. Just a little WD40 and scotch brite to clean it up a bit.
If it were me, I would spend the time on flattening the sole and getting it tuned and into work.
View OSB's profile
OSB
147 posts in 702 days
#4 posted 12-30-2016 06:42 AM
I prefer WD40 with bronze wool. It feels less aggressive than Scotchbrite but has worked well for me on blued steel with surface rust.
View Woodknack's profile
Woodknack
12401 posts in 2556 days
#5 posted 12-30-2016 06:48 AM
I would be very surprised if acid doesn’t remove Japanning. It will dissolve steel if you leave it in long enough. That’s how it works and why knife makers use it to expose patterns in damascus steel.
