Question on mitigating lunchbox planer noise
Forum topic by averagedadworkshop posted 12-27-2016 05:44 PM 1641 views 0 times favorited 15 replies Add to Favorites Watch
View averagedadworkshop's profile
averagedadworkshop
29 posts in 1395 days
12-27-2016 05:44 PM
Topic tags/keywords: question planer
So, I picked up a DW734 last weekend knowing that it was going to be loud, but underestimating the impact on my family. I am a basement hobby woodworker and quickly found that my two young boys were not fans of the amount of noise created by my new toy. I even tried hauling it up to the garage and running some boards through it out there, but I ended up with the same result, a crying little boy and I am taking the smallest pass I can. Anybody have thoughts on how to reduce the noise level?
-- "Do what you can, with what you have, where you are." - Theodore Roosevelt
15 replies so far
View JAAune's profile
JAAune
1838 posts in 2461 days
#1 posted 12-27-2016 05:49 PM
Helical heads are available for that planer if I’m not mistaken. That’s the only way to significantly reduce the noise level. It’s either that or you’ll need to work on sound-proofing the entire basement.
View TheFridge's profile
TheFridge
10290 posts in 1630 days
#2 posted 12-27-2016 05:52 PM
Sounds about right.
5093 posts in 2637 days
#3 posted 12-27-2016 06:06 PM
What they said^^^^. Those machines are just loud, period, and moving it out of earshot or finding a really well sound deadened room is about it. BTW, hook a DC to it and it will get a lot louder. One of the biggest advantage of the helical heads (among many) is the very good reduction in noise a planer makes.
averagedadworkshop
#4 posted 12-27-2016 07:34 PM
Thank you for the input! That’s what I was afraid of, unfortunately the helical head is out of the question at this point budget wise. I guess my next project is sound proofing the basement! :)
JAAune
#5 posted 12-27-2016 11:10 PM
Insulation and isolation are important for sound-proofing. I’m not an expert but I believe some of the other guys here have experience and links to articles explaining the concepts. There have been threads on the topic before that may be useful and should be easy to find with the search function.
View 8iowa's profile
8iowa
1581 posts in 3905 days
#6 posted 12-28-2016 12:45 AM
Soundproofing your basement is only 1/2 of the story.
Some of these universal motor planers have noise levels above 100 decibels, which can cause very rapid permanent hearing loss. Let me repeat, nothing is more permanent than permanent.
Purchase a set of very good hearing protectors, like the Peltor with 29 decibel reduction. use these with ear plugs as well.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2254 days
#7 posted 12-28-2016 05:58 PM
Fortunately, a planer gets used far less often than other tools, like your table saw.
I just pick and choose when I use my lunchbox planer…
It’s the one tool that drives my wife crazy, so I try not to use it when it’ll cause a conflict. Just plan ahead and get your stock surfaced in batches.
+100 on the Peltor 29 dB muffs. They’re so cheap, you can have a few pairs around the shop for easy grabbing.
View Carloz's profile
Carloz
1147 posts in 736 days
#8 posted 12-28-2016 07:53 PM
- 8iowa
I did not know they make Peltor with 29 decibel reduction for small kids.
averagedadworkshop
#9 posted 12-28-2016 10:06 PM
- 8iowa
That is something that I take seriously, I wear the same kind of ear muffs I use for shooting when working in my shop.
View Jim Finn's profile
Jim Finn
2679 posts in 3066 days
#10 posted 12-28-2016 10:33 PM
If you replace the blades it will become quieter…..for a while. As the blades dull, the noise level increases.
-- No PHD just a DD214 Website> craftingcouple.com
View papadan's profile
papadan
3584 posts in 3512 days
#11 posted 12-28-2016 11:23 PM
I just take mine outside and use it.
8iowa
#12 posted 12-30-2016 01:30 PM
Check out the selection of hearing protectors from midway-usa;
http://www.midwayusa.com/s?targetLocation=%2F_%2FN-10509%3FNo%3D0%26Np%3D2%26Nr%3DAND%2528p_visible%253A1%252Ccustomertypeid%253A1%2529%26Nrpp%3D144%26Ns%3Dp_metric_sales_velocity%257C1%26Ntpc%3D1%26Ntpr%3D1
There are several ladies and youth models available.
View pmayer's profile
pmayer
1029 posts in 3209 days
#13 posted 12-30-2016 02:35 PM
I agree with JAAune. Here’s some supporting evidence: I went from a Delta planer that screamed at about 105 db when planing wood, to a Woodmaster that dropped to 92db, then by adding a helical head to the Woodmaster I was down to 82 db.
View splintergroup's profile
splintergroup
2304 posts in 1366 days
#14 posted 12-30-2016 03:08 PM
Shooting muffs, for everyone in your family (and your neighbors!)
Seriously, these things are loud and I don’t think any amount of insulation will reduce the noise in the house to an acceptable level.
JAAune
#15 posted 12-30-2016 03:28 PM
Seriously, these things are loud and I don t think any amount of insulation will reduce the noise in the house to an acceptable level.
- splintergroup
Insulation is only part of sound-proofing. That combined with isolation and other vibration-dampening techniques can be effective but will certainly cut into headroom and floor space (and cost money).
