Finish over stain
Forum topic by zipmac22 posted 12-27-2016 12:41 AM 441 views 0 times favorited 3 replies Add to Favorites Watch
View zipmac22's profile
zipmac22
28 posts in 1000 days
12-27-2016 12:41 AM
Topic tags/keywords: question finishing
I’m new when it comes using stains, varnish, polyurethane, etc. I’ve stained my project and am going to put a polyurethane coat over the stain. My question is…do I need to sand over the stain before I apply the polyurethane? I can see sanding if I was using a stain/polyurethane mix instead of just the stain. Thanks!
-- Chris, Central Texas
3 replies so far
View TheFridge's profile (online now)
TheFridge
10343 posts in 1633 days
#1 posted 12-27-2016 01:02 AM
For me it depends on any grain raising.
MrUnix
6943 posts in 2346 days
#2 posted 12-27-2016 01:20 AM
I have never sanded after stain – it’s too easy to sand through and get an uneven look, and I’ve never found it necessary to do anyway. Oil based stain should not raise the grain, and if you are using a water based stain – you should raise the grain and sand back smooth first, before applying the stain. But I am by no means an expert on stain, as I rarely use it and prefer the natural look/color of the wood for most projects.
View cracknpop's profile
cracknpop
326 posts in 2496 days
#3 posted 12-27-2016 02:10 AM
Like the comments above, I do not sand after staining unless I find a rough spot I missed before staining. When I used to brush poly over stain, I would pour about as much as I would need in a separate container for the first coat as the brush will pick up some stain and transfer back to container. You may end up with tinted poly on subsequent coats.
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
