Glue one end of a breadboard end
Forum topic by TheChucker posted 1006 days ago 1231 views 0 times favorited 6 replies Add to Favorites Watch
View TheChucker's profile
TheChucker
38 posts in 1279 days
1006 days ago
I need to add breadboard ends to the table top for a table I’m constructing. I understand that the breadboard ends are only glued in one spot to allow for seasonal movement of the top. Typically, these are glued at the center of the breadboard and pinned on each end with elongated holes. However, with this table being up against a wall, I want to confine all the movement of the top to the back end, or that end which is against the wall.
Can I glue one end of the table top breadboard and pin the center and the other end to restrict the mvoement to the back? The top itself if about 44” x 19”.
-- Wherever you go, there you are.
View swirt's profile
swirt
1864 posts in 1138 days
#1 posted 1006 days ago
I can’t think of any reason why that wouldn’t work just fine. The pegged hole farthest from the glued end would need to be elongated more than the hole in the middle, but that’s no problem. Maybe I am missing something that someone else will catch, but I’d do it.
View tbone's profile
tbone
251 posts in 1850 days
#2 posted 1006 days ago
If the 19” is the width of the glued up boards, then I think you should be able to do that. However, keep in mind that some woods—and cuts of woods—move more than others, so I guess the definitive answer would depend on the species you are intending to use.
-- "You can lead a politician to water, but you can't make him think." Kinky Friedman
TheChucker
#3 posted 1006 days ago
19” is the width of the whole top. It’s three glued up boards in total at about 6.5” each and it’s made out of Cherry.
View Porchfish's profile
Porchfish
470 posts in 698 days
#4 posted 134 days ago
This should be a workable solution with dry cherry at the start. I have always followed the old fart’s rule that you always put the same finish on the bottom of a piece as the top, and the movement is limited even more !
-- some men see things that are and wonder why, I dream of things that never were and ask why not .... rfk
View Swyftfeet's profile
Swyftfeet
163 posts in 337 days
#5 posted 134 days ago
This would work fine from everything that I’ve read, but I’m curious why you wouldn’t want the flush edge to be the displayed edge? If it expands a couple sixteenths or contracts, the edge by the wall would never show it to the casual passerby, but if the displayed edge is the one doing all the movement, you’d see it…
-- Brian
View bondogaposis's profile
bondogaposis
1237 posts in 517 days
#6 posted 134 days ago
There is no reason that you can’t do this. Just remember that if someday you want change the arrangement of this table and the backside becomes the frontside, the movement will be double what it would be if you had glued it in the center.
-- Bondo Gaposis
