Routing dadoes for t track
Forum topic by Vrtigo1 posted 08-16-2010 03:04 PM 3410 views 0 times favorited 10 replies Add to Favorites Watch
View Vrtigo1's profile
Vrtigo1
434 posts in 3017 days
08-16-2010 03:04 PM
Any tricks here? I picked up some Kreg t-track over the weekend to use for positioning my router table fence and used a straight bit along with straightedges to rout the dado for it. Since the router makes a dado with a round end, I tried using a chisel to square up the edges with less than stellar results. The end of the dado isn’t perfectly flat, nor perfectly square to the sides so the t track doesn’t fit all the way flush against it. Luckily, the fence covers this so you won’t really see it much, but it got me wondering if there was a better way to go about it?
10 replies so far
View richgreer's profile
richgreer
4541 posts in 3100 days
#1 posted 08-16-2010 03:30 PM
A sharp, high quality, bit and multiple passes. I never take off more than an 1/8” in any pass.
Personally, I leave the round ends. They don’t bother me.
I also put some gorilla glue under the track before I screw it down. It’s probably not necessary but I do it anyway. Obviously, my track is permanently attached.
Vrtigo1
#2 posted 08-16-2010 05:38 PM
Thanks Rich. I did the first one in 1/8” passes, but got myself in a hurry for the second one. I figured since I’d already got the bit at the absolute correct depth that I’d route the second dado at the final depth since it’s only 3/8” deep. Probably would’ve been better to break it up, but I just went extra slow and it turned out fine.
Both of the dadoes look great, it’s just the rounded ends that I slightly butchered that are bugging me. In hindsight, I kind of wish that I’d just left them rounded.
View ajosephg's profile
ajosephg
1880 posts in 3587 days
#3 posted 08-16-2010 07:41 PM
Why not just rout it through the edge of the table? That’s how mine are.
-- Joe
Vrtigo1
#4 posted 08-16-2010 08:09 PM
I’d rather not have the tracks protrude past the fence, though I did think about that. I did route the grooves through the back of the table.
View Jim Finn's profile
Jim Finn
2658 posts in 2948 days
#5 posted 08-17-2010 01:08 AM
a belt sander or bench grinder will round off the “T” track to fit also.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View Gene Howe's profile
Gene Howe
10535 posts in 3454 days
#6 posted 08-17-2010 01:22 AM
You could always rout it through and insert a plug :-)
View reggiek's profile
reggiek
2240 posts in 3296 days
#7 posted 08-17-2010 01:31 AM
If using chisels, the best bet would have been to get and use some mortise chisels…they are built for this kind of work…there is even an angled one for corner cuts.
I like Jim’s idea of rounding the track too….it would make the track and dado mate each other…and give it a finished look.
You could use a spiral trim, flush trim or even a laminate trim bit. Use a laminate trim router, a dremel with a plunge base or just a plunge router – Clamp a block on top of the table along the square line, for the bits bearing to run along, and let the cutter square up the slot.
I have a set of diamond straight burs with my proxon that I use to square of mortises – the small bits allow me to take the cut slow and follow a square off line.
I have used all of these methods at one time or another…and I am sure there are many more others that can be tried.
Vrtigo1
#8 posted 08-17-2010 04:49 AM
Thanks reggie, I think I’ll try your suggestion with a dremel and plunge base next time. Seems pretty easy and sounds like it’ll do exactly what I needed.
View Steve Peterson's profile
Steve Peterson
377 posts in 3108 days
#9 posted 08-17-2010 05:50 PM
I left mine round so there is room to slide a hex bolt into the track.
-- Steve
View surfin2's profile
surfin2
51276 posts in 3162 days
#10 posted 08-18-2010 02:26 AM
I used my dremel with accouple bits to square it up & my Roto Zip to cut the T-Track, they both did an awesome job…
-- Rick
