Flatness Tolerance for new TS
Forum topic by BradinPA posted 08-16-2010 10:05 AM 1341 views 0 times favorited 2 replies Add to Favorites Watch
View BradinPA's profile
BradinPA
4 posts in 3091 days
08-16-2010 10:05 AM
Topic tags/keywords: question tablesaw
What is an acceptable tolerance of flatness for tablesaw tables?
I purchased a new Unisaw (but the old model) last fall. Because of busyness of life including a new baby, I am just now assembling the extension table to the saw. I am having a heck of a time lining up the edge of the extension to the saw table. I then measured with a straight edge and feelers and found the tablesaw table from the infeed side to the outfeed side and the outfeed is 0.015 out of flat and lower than the infeed. So I am having trouble lining up the entension table without a bump on the rear.
I could probably shim the extension table to be out of flat to match the tablesaw, but I am not sure I like that solution. Before I call up Delta, I was wondering what level of flatness is acceptable?
2 replies so far
View Sawdust2's profile
Sawdust2
1466 posts in 4286 days
#1 posted 08-16-2010 12:53 PM
I’m not sure what you are saying. Is it that the table top is thinner at the back end by .015 or that it is lower?
If it is thinner then get in touch with Delta. If it is lower then just shim up the back with a wedge or spacer.
View ajosephg's profile
ajosephg
1880 posts in 3759 days
#2 posted 08-16-2010 01:19 PM
It is my belief that shimming the extensions is standard operating procedure.
-- Joe
