Gluing different coloured stains together
Forum topic by roughcuts posted 12-26-2016 02:00 PM 607 views 0 times favorited 3 replies Add to Favorites Watch
View roughcuts's profile
roughcuts
18 posts in 662 days
12-26-2016 02:00 PM
Topic tags/keywords: question finishing
I am planning to glue a few pieces together, I’m just wondering how to go about it. If i glue them together, how do i sand everything to make it uniform and to remove all the glue?
Any help is appreciated
Thanks
3 replies so far
View dhazelton's profile
dhazelton
2789 posts in 2418 days
#1 posted 12-26-2016 02:04 PM
You could put a couple coats of your final finish on the face of the wood before you glue the edges. Glue will wipe right off and a VERY light sanding shouldn’t affect the color.
View splintergroup's profile
splintergroup
2253 posts in 1343 days
#2 posted 12-26-2016 03:40 PM
Alignment is the key, use splines or tongue/groove. You can also “hide” any misalignment with a shallow “V” groove at the joint. This is all to avoid any sanding.
roughcuts
#3 posted 12-26-2016 03:43 PM
Perfect. Thanks for the advice. Will try the final finish technique.
