| Forum topic by TheDane | posted 1007 days ago | 3625 views | 6 times favorited | 10 replies | ![]() |
1007 days ago |
Topic tags/keywords: jig pine sander bandsaw v-drum safety guard When I built my V-Drum Sander a couple of months ago ( http://lumberjocks.com/projects/29085 ), one thing that was missing was a guard covering the link belt. Though there were never any injuries, it never felt very safe … and if it doesn’t feel safe, it is not. Took care of that problem this weekend … the guard was made from a piece of 2×4, a scrap of plywood, a couple of hangar bolts and some knobs. The belt guard is removable (in case of belt changes or for cleaning), and it is adjustable.
-- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
10 replies so far
#1 posted 1007 days ago |
Fancyyyyyyyy!!! ;-) Looks very nice. -- Only the Shadow knows.................... |
#2 posted 1007 days ago |
I know what you mean, after a few months of working with mine I just knew this issue had to be address. Now that it done I feel more at easy during operating…nice work on your belt guard and enjoy using …BC |
#3 posted 1007 days ago |
That was a clever move, I can Imagine you feel more comfortable now. -- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking. |
#4 posted 1006 days ago |
Thanks for posting, I need to do that. That belt tensioner is genius too, I just went back and Favorited the sander build post. -- Good judgement comes from experience and experience comes from poor judgement. |
#5 posted 1006 days ago |
great idea speciel if any children visit you in the shop :—) Dennis |
#6 posted 1006 days ago |
Timbo—The tensioner was an after-thought that I should have thought of when I built it. The motor platform is attached to the case with a piece of piano-hinge (left over from attaching the top). Originally, I thought it would self-tension under the weight of the motor, and it sort of worked except the motor would always jump on startup. The tensioner is just a T-nut on the inside with a bolt through it … I epoxied a slug from the electrical box knockout to the case to keep the bolt from digging a hole in the plywood. Dennis & Mads—You are absolutely correct! It occurred to me that this could be a problem when I let my grand-sons (ages 8 and 10) use it (under careful adult supervision) a few months ago! This makes a very useful tool safer. -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#7 posted 1006 days ago |
Dane I have just looked at it again best thoughts |
#8 posted 1006 days ago |
Nice job -- In God We Trust |
#9 posted 992 days ago |
Very Cleaver on the guard and the belt tensioner! Started building my 18 inch Drum sander yesterday! Thx for all the great ideas! -- Ken, "Everyday above ground is a good day!" |
#10 posted 992 days ago |
I have gotten several PM’s regarding the guard and tensioner. Maybe a little further explanation is in order. To attach the guard, there is a block of wood (about 1” wide, 1 1/4” thick, 4” or 5” long) situated inside the 2 sides of the belt and screwed to the box. I then drove in a couple of hangar bolts. The 1/4” x 20 threads on the hangar bolts protrude through the side of the guard where the knobs are attached. That way, the guard can be easily removed in the event you need to service the belt. The tensioner is a 1/4” x 20 – 2” stove bolt. There is a t-nut installed in the motor mount, and a jam nut to lock it down. I epoxied a knockout from an electrical service box to the case so the bolt wouldn’t dig a hole for itself. The only thing the tensioner does is smooth out start-up. Without it, the torque of the motor would cause a jolt when I powered it up. It time, it might have damaged the piano hinge used to mount the motor to the case. -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
| Forum | Topics |
Woodworking Skill Share
8784 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1522 |
3542 |
15755 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2833 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
