Tablesaw Blades
Forum topic by MOJOE posted 08-16-2010 12:10 AM 1131 views 0 times favorited 7 replies Add to Favorites Watch
View MOJOE's profile
MOJOE
548 posts in 3176 days
08-16-2010 12:10 AM
I read an article on the net regarding the use of 7-1/4 inch circular saw blades on a tablesaw. Besides the lower cost, the author discusses less stress on the saw’s motor, and less burning of material. He also talks about not wasting as much material due to a thinner kerf. Anyway, it seemed interesting, and I was just wondering what your thoughts were…...I would hate to try is and damage my saw in some way.
Thanks,
joe
-- Measuring twice and cutting once only works if you read the tape correctly!
7 replies so far
View jusfine's profile
jusfine
2422 posts in 2833 days
#1 posted 08-16-2010 12:48 AM
You won’t damage your saw unless it’s made for less than a 7 1/4” blade…
You will have less height to cut with, and way less on the 45 degree cuts (or any angle for that matter).
The only reason I could think why it would be that much easier on the motor is because you not taking as much of a cut /rip, or if your motor is undersized.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View ChuckV's profile
ChuckV
3096 posts in 3434 days
#2 posted 08-16-2010 01:02 AM
I have seen people do this with no problems. If you have a SawStop, you might have to check to see if there are any special considerations.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View knotscott's profile
knotscott
7874 posts in 3282 days
#3 posted 08-16-2010 01:11 AM
It shouldn’t hurt your saw, but you’re not likely to get results as good as those from premium 10” blades.
View richgreer's profile
richgreer
4541 posts in 2981 days
#4 posted 08-16-2010 02:00 AM
My cordless circular saw has a very narrow kerf and it is only a 6” blade. In theory, I could use that blade on my TS, but I wonder if the blade could stand the torque from the saw. I know I wouldn’t hurt the saw, but I might hurt the blade.
View FWBGBS's profile
FWBGBS
21 posts in 3146 days
#5 posted 08-16-2010 02:03 AM
I’ve used an old 7 1/4” numerous times to cut pressure treated and nasty old plywood headed for the garbage. My Jet ProShop hasn’t shown any ill effects.
I use the circular saw blades to save the teeth on my good Woodworker II and Freud blades.
I got the idea from Matthias' website. Is this the place you’re talking about?
-- No sane man will dance ~ Cicero
MOJOE
#6 posted 08-16-2010 04:29 AM
I did read about this on Matthias’ website…..cool site, I really like his perspective on things
FWBGBS
#7 posted 08-16-2010 03:07 PM
Yes indeedy.
His engineering background shines through both his projects and his solutions.
