| Forum topic by Luke | posted 1009 days ago | 4128 views | 0 times favorited | 31 replies | ![]() |
1009 days ago |
Topic tags/keywords: lie nielsen bench plane hand plane plane smoother I am trying to decide whether to buy the LN #4 bronze or the LN #4 1/2. I don’t really know what the difference would be so I was wanting to see if anyone had either or had an idea which would be a better all around smoother. I mainly want it to finish leveling my boards after all machining and edge glueing and then whatever other general uses come up including a finishing touch on the faces of parts. -- LAS, http://www.abettersign.com |
31 replies so far
#1 posted 1009 days ago |
I would swop a truckload of my African timber for ANY Lie-nielsen plane! -- Div @ the bottom end of Africa. "A woodworker's sharpest tool should be his mind." |
#2 posted 1009 days ago |
JorgeG, I really like the idea but I worry that it won’t do really well on face grain being so low. Is this unfounded? I have a low angle LN block plane already which I use for end grain and other things. -- LAS, http://www.abettersign.com |
#3 posted 1009 days ago |
I have the LN 4 1/2 bronze special edition smoother with a high angle frog. I would not recommend a standard frog for any smoothing plane. High angle 50 degree will work for most applications. The 55 degree is for very difficult grains and where a person is doing a lot of it on a regular basis. -- Oldworld, Fair Oaks, Ca |
#4 posted 1009 days ago |
>Which LN to get ?< My first responce is one of each. I love the things. But . . . For a working smoother and if you don’t have the bucks to buy several planes, who does these days, I STRONGLY recommend this plane ( sorry LN I still love you ) : http://www.leevalley.com/us/wood/page.aspx?p=51870&cat=1,41182,41187&ap=1 You should be looking at a LV ( some times the link to a specific Lee Valley catalog page fails so I included a photo ) Bevel Up Smoother. I have the wide one. Killer tool ! I have many blades for it. I have many other planes I reach past to get to this one. Brilliant tool. The other photo I included, I think obviously, is a LN Bronze. I bought early on when I knew even less than I know now. Nice to look at. http://i801.photobucket.com/albums/yy298/noydb1/th_OhYah.jpg http://i801.photobucket.com/albums/yy298/noydb1/th_Bronze4.jpg -- jsdnnoanybtr but you can call me jr |
#5 posted 1009 days ago |
http://i801.photobucket.com/albums/yy298/noydb1/Bronze4.jpg Ok that was harder than it needed to be. Guess I gotta study up on photo posting here. -- jsdnnoanybtr but you can call me jr |
#6 posted 1009 days ago |
Ha, ha, ha, aaahhhh, Ha, ha, ha, ha -- jsdnnoanybtr but you can call me jr |
#7 posted 1009 days ago |
Between the 4, 4 1/2 and the low angle smoother I say, get all three. You only live once. I have the 4 1/2 and I got it since it is a littel bigger than the 4. Also Deneb Puchalski from LN recommended the 4 1/2 over the 4 when I saw him at a LN show. I have also heard nothing but good things about the low angle smoother and that will be my next LN plane. Also, remember, LN products are made here in the USA so I always prefer the American made products especially when they are of superior craftsmanship. |
#8 posted 1009 days ago |
Div, how big is the truck? Maybe we could arrange something…? -- Randy "You are judged as much by the questions you ask as the answers you give..." |
#9 posted 1009 days ago |
Just to offer a different opinion. I suggest the #4. I don’t really understand the fascination with the wide road-grader planes. They complicate sharpening and require a lot more force in use. If you normally use pretty mild run-of-the-mill woods get the 50º frog. If you use figured or quarter sawn wood, get the 55º frog. I think O-1 is a better steel for woodworking tools than A-2 so get it with an O-1 iron. I suggest you get a regular bench plane and avoid the bevel-up planes. The claim of versatility comes over a very narrow range and costs a lot in edge retention. |
#10 posted 1009 days ago |
hmmm… I believe I am a little more befuddled than before. So many different opinions. If the angle of the low angle smoother is pretty much the same as the regular smoothers then why go for the low angle? It costs a bit less so that’s a consideration but I don’t really care about cost at the moment. Oh, but I still only want to buy only one plane for now. Wish I could buy a couple but I have other responsibilities to take care of too… he -- LAS, http://www.abettersign.com |
#11 posted 1009 days ago |
I have nearly everythin LN sells, and I was given much advice from salesman and other woodworkers when it comes to planes. most of it was crap. the first plane I ever owned was a LN 4 1/2 . and it is good if you don’t have much smoothing to do, also being able to switch it to 50 and 55 frogs is nice. for much smoothing, it is heavy. which is why I would recommend a LN number 3. the narrower blade is easier to hold to sharpen if you are new, and the bed angle will handle 95 percent of wood if sharpened and tuned properly. the wood that it won’t handle, you are better off to scrape(or just not use) anyway. -- Junior -Quality is never an accident-it is the reward for the effort involved. |
#12 posted 1009 days ago |
My collection of planes has grown over the last couple years including a #4 bedrock, 4 1/2 Veritas plane and a LN #164 bevel up plane. I use all of them and they work well. I have the mind set of big projects, big planes small projects, small planes. I use a 4 1/2 on larger projects and a 4 and sometimes a 3 on smaller projects. I bought the the 164 speciifically for gnarly wood. I ground the blade to 43 degrees providing the the equilivent of a high angle frog and it is a dream to use. Do not discount the bevel up smoothers, for the price of a blade and some grinding you can get two planes out of one. Good Luck. -- Marc |
#13 posted 1009 days ago |
The other thing you can do is to attend one of the Lie Nielsen Hand Tool Events. At those shows they have every tool they make and you can use them all under their instruction and find out which you like the most. Here is a link to the shows. http://www.lie-nielsen.com/?pg=1 One might be coming near you. |
#14 posted 1009 days ago |
>Don’t really care about cost [for one plane] at the moment< “Clark and Williams” http://www.planemaker.com/products.html I haven’t shelled out for one yet cause of my ideosincratic projects but for more normal stuff these are the advantages: Light weight Could be hard to get from maker. Could go with used. A new one would be my first choice. -- jsdnnoanybtr but you can call me jr |
#15 posted 1009 days ago |
Since JorgeG and I have the same plane I don’t feel like too much of a jerk in saying the adjuster is better on the Lee Valley Veritas smoother. The adjuster on the Lie Nielsen low angle or low angle jack can act as a gear, grip the slot of the blade and cause the blade to change angle when you only want to advance or retract the blade. Even with fettling ( smoothing ) of the disc on the adjust knob and fettling of the slot on the LN blade it can still trip you up. LN good for rougher work with a cambered blade; an inadvertent change in angle of blade is not critical. For a smoother with almost no camber ( curve on the blade edge ) give me the Veritas adjuster any day. -- jsdnnoanybtr but you can call me jr |
| Forum | Topics |
Woodworking Skill Share
8790 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1529 |
3547 |
15763 |
Hand Tools
2034 |
Jigs & Fixtures
494 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6155 |
