| Forum topic by Dan Hux | posted 1006 days ago | 807 views | 0 times favorited | 10 replies | ![]() |
1006 days ago |
What will work to remove oil based primer, paint and stain from my garage floor. I know this is not a woodworking problem, but it got this way due to my woodworking fun and joy. I’d like to finish my floor but I need to remove some of the old primer and paint on the floor. Is there a magic cleaner/sander that will remove this stuff. Any and all comments are welcome. The floor is concrete, the stains have some age on them, some years old, some only a year. I just tried paint stripper (had a small amount on hand) the concrete sucked it up, the quickcrete floor finish i bought comes with some sorta acid, that may work. Thanks, -- Dan Hux,,,,Raleigh, NC http://whitdaniel.com |
10 replies so far
#1 posted 1006 days ago |
I have never tried it on concrete, and it’s not magic, but Bix stripper will work on all the materials you mention. The other option is having your floor ground or sandblasted by a professional. -- Wish I were Norm's Nephew |
#2 posted 1006 days ago |
A friend of mine who owns an auto repair business had a similar situation….he had his professionally done…but a DIY could probably find the equipment at a good rental facility. First the guy ran a machine that uses hard plastic balls to pulverize the floor and remove the old paint and oil (very similar to a sandblaster…but using larger “sand”). I recall this machine looked like a large carpet cleaner. After cleaning, they put on a concrete etch and a layer of primer (they used a commercial spray gun…here again an item could be rented). Then they laid down a epoxy coating. The commercial guys used a machine that painted and applied heat to cure the floor very quickly as the shop could not be completely shut down for two days…even on the weekend….this could be done by roller or hand and given the time to cure/dry would take a few days or so. Of course in your situation you probably could use a concrete deck paint without all the hard core preparation since you don’t have as much oil and solvents as an auto shop does. I have to say though that the commercial application was extremely durable and very smooth – I would love to do this to my shop…and I possibly will in the future. -- Woodworking.....My small slice of heaven! |
#3 posted 1006 days ago |
Is it fresh or cured (the stain, etc)? Is the floor concrete? If it is, and well aged, nothing beats sandblasting for cleaning concrete. It’s hard to rent a sandblaster (I tried once, plus it takes a trailer-sized compressor), but the work can be hired out. Edit: a day late and a dollar short – again! -- My broker promised me he would treat my money as if it were his own. Trouble is, he did. |
#4 posted 1006 days ago |
I assume by your post that your concrete floor is not a glass smooth surface and that the surface has some degree of texture which prohibits simple scraping off of the floor. So I would use a chemical stripper on the spots needed and get as much up as possible. Then take a right angle grinder and attach a twisted wire cup brush to remove the rest of the paint from the floor. What won’t come up then should be prepped well enough to use epoxy paint to finish the floor. -- I don't make mistakes, I have great learning lessons, Greg |
#5 posted 1005 days ago |
Muriatic acid is commonly used for cleaning concrete when nothing else does the job. I’ve never used it, but as I understand you can get it at paint supply stores. Just be careful and be sure to follow all the safety instructions. |
#6 posted 1005 days ago |
I am sometimes disturbed by the crap on my shop floor, but quickly get over it and go back to work. I do wish for a seperate area for the dirty work though. -- She thought I hung the moon--now she just thinks I did it wrong |
#7 posted 1002 days ago |
id say go with muriatic acid and possibly rent a floor scarifier, we use one for demolition work when we have to grind off old floor carpet mastic -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#8 posted 1002 days ago |
Muriatic acid should work but it has very strong fumes make sure you have good ventilation and a means to flush it with water. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#9 posted 987 days ago |
I don’t know how to tell you to get it up, but I have a suggestion for everyone for future spills and drips. |
#10 posted 987 days ago |
How are you going to finish the floor? If you’re going to paint it, just paint over it. Try a couple of paints to make sure it dosn’t bleed through. -- Bruce from Central New York...now, if you'll pardon me, I have some sawdust to make. |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15748 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
