Wormy Maple
Forum topic by Fiddy posted 12-24-2016 09:18 PM 763 views 0 times favorited 4 replies Add to Favorites Watch
View Fiddy's profile
Fiddy
184 posts in 1454 days
12-24-2016 09:18 PM
Topic tags/keywords: wood wormy finishing maple
Today I got a load of wormy maple and what appears to be a good deal – need to make some drawer fronts and various finishing parts for new shop projects.
I’ve never worked with it before and therefore never finished it. Looking for any advice on finishing products, techniques, etc.
Thanks in advance and Merry Christmas!
View jeffswildwood's profile
jeffswildwood
3508 posts in 2121 days
#1 posted 12-24-2016 09:31 PM
I too was gifted a quantity of wormy maple. What I am going to do is sacrifice some cut offs and try different finishes. That way I can see what works and what I like.
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
View WDHLT15's profile
WDHLT15
1776 posts in 2620 days
#2 posted 12-25-2016 03:47 AM
I like a clear finish on it. Either an alkyd varnish or a satin poly like the Satin Minwax Fast Drying Polyurethane.
View crippledcarpenter's profile
crippledcarpenter
29 posts in 2590 days
#3 posted 12-26-2016 01:13 AM
it is actually ambrosia maple. caused by the ambrosia beetle. the staining is from there castings as they bore through the wood. every piece is unique. very cool. the finish should be whatever you feel most comfortable with and have had the best success. I like armor seal urethane. oil based, thin , easy to apply and forgiving in application. it is a general finishes product. a alternative finish, depending on what the project is, could be a Danish oil , sand paper applied. takes some time but with the right project, can have stellar results. what ever way you choose, don’t rush the finish. it takes as long as it takes.
-- haste makes firewood.
View Cheapguy82's profile
Cheapguy82
78 posts in 677 days
#4 posted 01-05-2017 03:23 PM
I used poly on it for one of my projects and I liked how it came out. You can go to my ‘projects’ page and check it out. Also, I saw a project that @Boxguy did with ambrosia maple. I think it was called ‘Boxguy goes camo’. He describes his finishing method in another spot, but he used tung oil, then wipe on poly, then paste wax. His stuff is beautiful. I’m still learning…
-- Stephen - Georgia
