Delta 36-725 Help
Forum topic by Offthatwall posted 12-24-2016 02:51 PM 499 views 1 time favorited 8 replies Add to Favorites Watch
View Offthatwall's profile
Offthatwall
5 posts in 608 days
12-24-2016 02:51 PM
I recently got a Delta 36-725 TS and I’m having some difficulty adjusting the blade alignment. I’ve been using this video and this power point to adjust it but when I loosen the two screws as instructed, the motor doesn’t budge. I’ve tried various degrees of looseness and had others check my work but nothing seems to work. I’m sure there is something I am missing, maybe some safety feature I have to disengage first but I can’t locate it for the life of me. Any help would be appreciated.
8 replies so far
View WhyMe's profile
WhyMe
1031 posts in 1617 days
#1 posted 12-24-2016 03:31 PM
I’m of no help because when I loosened those two set screws on my 36-725 the motor will move. So I don’t know what the issue is. I put both of my hands on it when turning it. One hand towards the blade end and the other hand on the butt end of the motor and twisted in opposite directions.
View coxhaus's profile
coxhaus
93 posts in 950 days
#2 posted 12-24-2016 03:37 PM
I found this on the net. I don’t one of these so use at your own risk.
https://www.youtube.com/watch?v=AK5MLWRHIa8
If this does not work then just scan the net.
Offthatwall
5 posts in 608 days
#3 posted 12-24-2016 03:54 PM
I m of no help because when I loosened those two set screws on my 36-725 the motor will move. So I don t know what the issue is. I put both of my hands on it when turning it. One hand towards the blade end and the other hand on the butt end of the motor and twisted in opposite directions.
- WhyMe
That is what I have been doing and nothing moves. I have even gone as far as taking the two bolts completely out and and it still doesn’t budge.
I found this on the net. I don t one of these so use at your own risk.
- coxhaus
That is the video that I have been using and linked in my original post. The video follows the same steps as every thing else I can find online but it simply isn’t working on my saw. After searching half the day yesterday I can’t find anyone else with the same issue.
View knotscott's profile
knotscott
8080 posts in 3432 days
#4 posted 12-24-2016 04:03 PM
Wondering if it needs a little tap to break free.
Offthatwall
5 posts in 608 days
#5 posted 12-24-2016 04:05 PM
- knotscott
I guess I might as well try, I just imagine the amount of times I have tried to twist the motor it would have broken free already.
Offthatwall
5 posts in 608 days
#6 posted 12-24-2016 04:13 PM
- knotscott
Well that worked, I grabbed a 2×4 and a hammer, whacked the motor a hand full of times and it seems to be twisting now. Not sure why I didn’t try that earlier but I appreciate the suggestion.
knotscott
#7 posted 12-24-2016 05:31 PM
- knotscott
Well that worked, I grabbed a 2×4 and a hammer, whacked the motor a hand full of times and it seems to be twisting now. Not sure why I didn t try that earlier but I appreciate the suggestion.
- Offthatwall
You’re welcome. Hope the rest of your day (and mine) is that simple! ;-)
WhyMe
#8 posted 12-24-2016 06:26 PM
I was thinking about saying to give it a whack but the motor case is plastic and I wasn’t sure that was good advise.
